Silicone and sealers talk. Small block #2398686
11/05/17 05:49 AM
11/05/17 05:49 AM
CA.
RAY1969CARS Offline OP
CA.
Hi guys tell me which silicone and sealer you like to use it on. Various Gaskets on small blocks Oil pan ,rear main seal, front cover etc. etc. thanks
Mopar or no car !
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2398724
11/05/17 11:12 AM
11/05/17 11:12 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The two that I've used most recently have been Permatex Ultra Black, which they state is intended for sealing oil pans, etc, and their Hi Temp Red, which has been my standard go-to RTV for engine assembly. I'm sure there are other good products, too.
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2398747
11/05/17 11:59 AM
11/05/17 11:59 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use Ultra copper where the ends of the rear main seals meet the gaskets, a small amount around the wet holes on the timing cover and a bead in place of the end seals on the intake.
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2398758
11/05/17 12:20 PM
11/05/17 12:20 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Valco Cincinnati All-In-One Aluminum Silicone.
The best stuff i have ever used!
Joe
Without Data, you’re just another guy with an opinion.
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2398865
11/05/17 03:00 PM
11/05/17 03:00 PM
Gas A Cinch (SP?) for sealing and sticking all the gaskets on except the head gaskets and rear main seals up
Adhesive silicone only for BB rear main seal holder to the block to seal up the side seals and in the corners of the intake manifolds and or valley pans up
Thermostat silicone on the water pump and thermostat housing gaskets up
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2398876
11/05/17 03:21 PM
11/05/17 03:21 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Gasgacinch, Cab. I think it still comes in that old-style can with the big ol' dauber.
Ultra Black, clear silicone for intakes, Hi-Temp Copper for headers (trued surfaces, no gaskets, adapter plates & Stahls on my car)
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2398881
11/05/17 03:36 PM
11/05/17 03:36 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The only thing I ever use anymore is Permatex Aviation Form-A-Gasket. A thin coat brushed on the gasket and allowed 10 minutes to tack up. There is a place for silicone from time to time, but this stuff works and stays tacky, never hardens.
http://www.aircraftspruce.com/catalog/ep...ASABEgLSevD_BwE
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2398936
11/05/17 05:38 PM
11/05/17 05:38 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
None of you use "The Right Stuff"? I used it for everything on my 400 and am super impressed with it. Not cheap though...
Re: Silicone and sealers talk. Small block [Re: Dave Hall] #2398941
11/05/17 05:47 PM
11/05/17 05:47 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Have you had to take anything apart yet? sawzall hammer grin
It is really good stuff, just gotta be careful what you use it on, it almost welds parts together.
I use Permatex Ultra black on most stuff, and the gray on parts that I don't want to take apart for a long time, it is fairly hard to get apart too sometimes on certain things.
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2399000
11/05/17 07:03 PM
11/05/17 07:03 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I prefer Black Silicone (16B) over the Ultra Black. But I have been using the Gray more here lately, depending on the application. I'm not a big fan of smearing that stuff all over everything. Just a touch on the rear seal and rear cap joints. A dab in the corners of the pan gasket, end seal joints. The ends of the intake. Maybe a smear around the water passage areas of the timing cover if it shows any corrosion damage. That's it.
Re: Silicone and sealers talk. Small block [Re: CMcAllister] #2399015
11/05/17 07:39 PM
11/05/17 07:39 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
used the right stuff one time and swore it off the first time I had to dis assemble it, I think welding the intake on would of been easier to take off.
Re: Silicone and sealers talk. Small block [Re: ProSport] #2399035
11/05/17 08:44 PM
11/05/17 08:44 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I replaced the water pump with the stuff on there. I didn't notice any difference from regular black or whathaveyou???
Re: Silicone and sealers talk. Small block [Re: Dave Hall] #2399047
11/05/17 09:09 PM
11/05/17 09:09 PM
Try removing the oil pan or valve covers or valley pan with that stuff on the gaskets hammer It ain't right after all on them whistling
Re: Silicone and sealers talk. Small block [Re: StealthWedge67] #2399058
11/05/17 09:27 PM
11/05/17 09:27 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Is this blue? If so, I think Permatex used to call it Hylomar. It's the only gasket sealer I use anymore.
Hylomar is still available, but comes from England and is pretty spendy.
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2399085
11/05/17 10:15 PM
11/05/17 10:15 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
More recently, I've used Permatex Ultra Black Or the High Temp Red. I do like using Right Stuff on differential covers.
What I've found as I've gotten older is that high quality gaskets are usually the most important thing for proper seal.
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2399093
11/05/17 10:25 PM
11/05/17 10:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Permatex makes a sealer specifically for the chemicals in gear oil for rear end applications.
Re: Silicone and sealers talk. Small block [Re: RAY1969CARS] #2399204
11/06/17 04:38 AM
11/06/17 04:38 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I remember Mopar carried different kinds for axle, trans., oil, etc... I think I used them all with success at one time or another. If this is a race only engine that comes out of the car and apart every year you could probably get away with anything. If you are depending on sealant to take the place of a gasket? I recommend The Right Stuff. For little tacky-tac here or there to help gaskets? Then use what is made for that app or The Right Stuff, sparingly. coffee
