Re: Inital 408 timing and other ??????
[Re: Dodgem]
#239876
03/01/09 03:05 PM
03/01/09 03:05 PM
RapidRobert
I'm assuming that you dont have room to use the thicker 70 & up w/p that would put the hose on the pass side with the rad nipple? What he said, find true tdc, make a sturdy coat hanger pointer(or buy that one off eGay). Mark the dampener your self .0632683" is 1 degree so 10 degrees initial would be .633" & 32 total would be 2.025". Cut 2 pieces of coat hanger wire with your side cutters, trim the ends square & to the these exact lengths with a file & with your 0-1" & 2-3" micrometers & use the 2 pieces curved onto the circumference of the harmonic dampener to measure & mark your new EXACT timing marks & your perfect. EDIT someone(I forget who) offers a hi perf version of the early cast iron water pump which might be a good addition for you.
[Re: RapidRobert]
#239877
03/02/09 11:14 PM
03/02/09 11:14 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
My 408 liked 18 initial and 35 total
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: aarcuda]
#239880
03/03/09 01:13 PM
03/03/09 01:13 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
I run the '69 and earlier pump with the lower hose on the driver's side. I bought a '68 and earlier timing pointer and reindexed the damper so I could set it via the passenger's side: https://board.moparts.org/ubbthreads/show...rue#Post5056990I run my SB stroker's timing at 32 degrees locked. He to lock it to calm down in gear idle. Starts easily so not a problem. I don't know if 32 is the best yet, haven't had a chance to measure the effects of other settings.
[Re: 69Cuda340S]
#239881
03/03/09 04:35 PM
03/03/09 04:35 PM
Posts: 711 Montana
Posest
Montana
Do any of you run power steering with this shorter pump? If so could you post a few pics. Thanks
