Inital 408 timing and other ?????? #239874
03/01/09 01:28 PM
03/01/09 01:28 PM
Montana
P
Posest Offline OP
Posest  Offline OP
P
Montana
Hello all,
I have my engine running and have even drove the pick up. (WOW) My only two questions are first,where should I set my timing at. I started it and broke the cam in at 10 btc. Engine specs are as follows. Scat balanced rods and crank, KB hyper 10.5:1 pistons J heads 2.02's with gasket match porting and some bowl work 64cc chambers, Block has been decked for a true 10.5. I am running the Lunati 60405 with matching springs,retainers keepers and Harland Sharp rockers.Exhaust is shorty headers out to 2 1/2 exhaust. Have not adjusted rockers or timing yet. Also this is a 89 Dakota that has no room between the water pump and rad. Therefore I have a 69 cast iron pump but it is tough to time the engine because it exits over the timing tab, runs down and under the balancer to the passenger side rad. Full tube headers on the way. Any ideas on the timing or the water pump would be greatly appreciated.
Shawn
Re: Inital 408 timing and other ?????? [Re: Posest] #239875
03/01/09 01:59 PM
03/01/09 01:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
well you could mount a pointer on the other side find true TDC and paint a white line for your new 0.
generally you want 35 to 36 total with vacuum advance unhooked and if you feel the need to hook up vacuum advance in the future make sure it is on ported vacuum and NOT manifld.
Re: Inital 408 timing and other ?????? [Re: Dodgem] #239876
03/01/09 03:05 PM
03/01/09 03:05 PM
I'm assuming that you dont have room to use the thicker 70 & up w/p that would put the hose on the pass side with the rad nipple? What he said, find true tdc, make a sturdy coat hanger pointer(or buy that one off eGay). Mark the dampener your self .0632683" is 1 degree so 10 degrees initial would be .633" & 32 total would be 2.025". Cut 2 pieces of coat hanger wire with your side cutters, trim the ends square & to the these exact lengths with a file & with your 0-1" & 2-3" micrometers & use the 2 pieces curved onto the circumference of the harmonic dampener to measure & mark your new EXACT timing marks & your perfect. EDIT someone(I forget who) offers a hi perf version of the early cast iron water pump which might be a good addition for you.
Re: Inital 408 timing and other ?????? [Re: RapidRobert] #239877
03/02/09 11:14 PM
03/02/09 11:14 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
My 408 liked 18 initial and 35 total
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Inital 408 timing and other ?????? [Re: Kam*Kuda] #239878
03/02/09 11:31 PM
03/02/09 11:31 PM
Montana
P
Posest Offline OP
Posest  Offline OP
P
Montana
I will play with it some more when it is back together. Rear axles are out waiting on new and new rims on the way. Dash cluster is out now, trying to put my tach where the gas gauge was. Full length headers should be here any day now. Darn that sounds like a lot when I only have 1 arm right now. Had the other cut on a week ago.
Thanks for the replys
Shawn
Re: Inital 408 timing and other ?????? [Re: Posest] #239879
03/03/09 09:12 AM
03/03/09 09:12 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
my 416 is set to 20 initial and 32 total. next weekend, I'll take it to the track and try 30 degrees, 34 and 36 degrees and see is it picks up any
Re: Inital 408 timing and other ?????? [Re: aarcuda] #239880
03/03/09 01:13 PM
03/03/09 01:13 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I run the '69 and earlier pump with the lower hose on the driver's side. I bought a '68 and earlier timing pointer and reindexed the damper so I could set it via the passenger's side:
https://board.moparts.org/ubbthreads/show...rue#Post5056990
I run my SB stroker's timing at 32 degrees locked. He to lock it to calm down in gear idle. Starts easily so not a problem. I don't know if 32 is the best yet, haven't had a chance to measure the effects of other settings.
Re: Inital 408 timing and other ?????? [Re: 69Cuda340S] #239881
03/03/09 04:35 PM
03/03/09 04:35 PM
Montana
P
Posest Offline OP
Posest  Offline OP
P
Montana
Do any of you run power steering with this shorter pump? If so could you post a few pics.
