Re: How much ET gain do you see in autumn months?
[Re: dvw]
#2396759
11/01/17 04:56 PM
11/01/17 04:56 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Less than a tenth in the 1/8..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Uncle Barry]
#2396814
11/01/17 06:21 PM
11/01/17 06:21 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
I picked up .08 in the 1/8th. Wasnt mineshaft air but the DA was at 700'.
Ok
[Re: cudatom]
#2396817
11/01/17 06:23 PM
11/01/17 06:23 PM
Posts: 4,701 Wichita
GY3
Wichita
11.30's in hot, muggy summer
Low 11.20's in Spring/Fall.
Overall about .08
[Re: Uncle Barry]
#2397139
11/02/17 01:45 AM
11/02/17 01:45 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I picked up a little over a tenth on a great day a couple of weeks ago over the heat of summer.
[Re: Uncle Barry]
#2397148
11/02/17 01:59 AM
11/02/17 01:59 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Last month I went 135mph PB in the middle of Australia @ 3800 ft, Im back west now and at my home track I could see 500ft and night air, hoping for 137 and a 9.9
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Uncle Barry]
#2397159
11/02/17 02:47 AM
11/02/17 02:47 AM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
2 weeks ago I had a 1/10 swing over the day 7 passes , track championship round. this weekend with a national event prepped track I am hoping for a bit less than that .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Uncle Barry]
#2397310
11/02/17 02:30 PM
11/02/17 02:30 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
Usually a tenth or two. I still have the stock hood so I don't get the benefit of the cooler air until later in the run. Regardless of outside temp my air inlet temperature is usually 130-150* on the starting line, it then tapers down through the run and drops closer to ambient.
68 Barracuda Formula S 340
[Re: Uncle Barry]
#2397315
11/02/17 02:37 PM
11/02/17 02:37 PM
Posts: 13,386 Marion, South Carolina [><]
an8sec70cuda
Heat of summer July and August...high 9.8s to 9.90s. Decent summer air...9.70s. Good fall air...9.60s or maybe 9.50s if it's real good.
This is N/A on pump gas. My old motor that ran on C12 didn't seem to fall off as much in hot weather. Possibly due to the fuel?
[Re: Uncle Barry]
#2397360
11/02/17 03:36 PM
11/02/17 03:36 PM
Posts: 7,506 Az
Crizila
Az
Temp can make a difference - if you jet up for it - which most don't. Still can help a little. Big difference comes with a change in DA.
Fastest 300
[Re: Uncle Barry]
#2397380
11/02/17 04:09 PM
11/02/17 04:09 PM
an8sec70cuda
I try to keep it simple. When the weather turns hot in the spring, I lean the carb out 2 jet sizes front and rear and don't bother it again until the air gets good again in the fall. I've tried chasing jetting for different conditions (years ago) and honestly never seen much change. The only time I'll stray from that is if I'm going to the track on a day I know the air will be extremely good. Then I'll try jetting it up more for a good timeslip.
