How much ET gain do you see in autumn months? #2396594
11/01/17 12:14 PM
11/01/17 12:14 PM
Big Western Pencilveinya
U
Uncle Barry Offline OP
U
Just curious what gains you guys and gals see in the cooler months. work
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2396599
11/01/17 12:24 PM
11/01/17 12:24 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
My cars typically pick up a good tenth, tenth n a half (1/4 mile), but at most 2 tenths (Cool days with a little tail wind). I see other cars that pick up alot more, but they their cars aren't as consistent on a race day either...A lot has to do with carb size and jetting. Most of my stuff has to small of carb on it, but it runs more consistent that way.
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2396641
11/01/17 01:40 PM
11/01/17 01:40 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I've been 9.11/9.12 in good air in the summmer, 9.28-9.30 in 100 degrees. Best ever in the fall, 9.04.
Doug
Re: How much ET gain do you see in autumn months? [Re: dvw] #2396759
11/01/17 04:56 PM
11/01/17 04:56 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Less than a tenth in the 1/8..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2396764
11/01/17 05:07 PM
11/01/17 05:07 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Enough so that if you wait until October weather comes and it rains there's no chance for a best ET until spring
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2396772
11/01/17 05:15 PM
11/01/17 05:15 PM
P
Paul_Fancsali Offline
P
Hot thermostat 195 and cool air have given me .2 in one case.4 when the car bit hard
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2396814
11/01/17 06:21 PM
11/01/17 06:21 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I picked up .08 in the 1/8th. Wasnt mineshaft air but the DA was at 700'.
Ok
Re: How much ET gain do you see in autumn months? [Re: cudatom] #2396817
11/01/17 06:23 PM
11/01/17 06:23 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
11.30's in hot, muggy summer
Low 11.20's in Spring/Fall.
Overall about .08
'63 Dodge 330
11.19 @ 121 mph
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2397139
11/02/17 01:45 AM
11/02/17 01:45 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I picked up a little over a tenth on a great day a couple of weeks ago over the heat of summer.
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2397148
11/02/17 01:59 AM
11/02/17 01:59 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Last month I went 135mph PB in the middle of Australia @ 3800 ft, Im back west now and at my home track I could see 500ft and night air, hoping for 137 and a 9.9
1963 Plymouth Max Wedge
1971 Barracuda
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2397159
11/02/17 02:47 AM
11/02/17 02:47 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
2 weeks ago I had a 1/10 swing over the day 7 passes , track championship round.
this weekend with a national event prepped track I am hoping for a bit less than that .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: How much ET gain do you see in autumn months? [Re: SILVER67] #2397162
11/02/17 02:55 AM
11/02/17 02:55 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^ain't that the truth^^^ my best has .08 quicker in the fall months ben in the 40's this summer , hoping to get a new best this year but don't look like that's going to happen violin
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2397246
11/02/17 12:03 PM
11/02/17 12:03 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
My combination is NOT typical and EXTREMELY air flow challenged, so I can see 3-4 tenths difference from 4000' DA to sea level air. I'm also not shooting for consistency. I ran 12.39 at 4000' DA at Indy and ran 12.13 at 200' DA at MIR. Keep hoping for anything under sea level! Three races left, maybe Atco.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2397310
11/02/17 02:30 PM
11/02/17 02:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Usually a tenth or two. I still have the stock hood so I don't get the benefit of the cooler air until later in the run. Regardless of outside temp my air inlet temperature is usually 130-150* on the starting line, it then tapers down through the run and drops closer to ambient.
68 Barracuda Formula S 340
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2397315
11/02/17 02:37 PM
11/02/17 02:37 PM
an8sec70cuda Offline
Heat of summer July and August...high 9.8s to 9.90s.
Decent summer air...9.70s.
Good fall air...9.60s or maybe 9.50s if it's real good.
This is N/A on pump gas. My old motor that ran on C12 didn't seem to fall off as much in hot weather. Possibly due to the fuel?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2397360
11/02/17 03:36 PM
11/02/17 03:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Temp can make a difference - if you jet up for it - which most don't. Still can help a little. Big difference comes with a change in DA.
Fastest 300
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2397380
11/02/17 04:09 PM
11/02/17 04:09 PM
I try to keep it simple. When the weather turns hot in the spring, I lean the carb out 2 jet sizes front and rear and don't bother it again until the air gets good again in the fall.
I've tried chasing jetting for different conditions (years ago) and honestly never seen much change.
The only time I'll stray from that is if I'm going to the track on a day I know the air will be extremely good. Then I'll try jetting it up more for a good timeslip.
CHIP
Re: How much ET gain do you see in autumn months? [Re: Uncle Barry] #2397521
11/02/17 10:09 PM
11/02/17 10:09 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
.2 and 2 mph comparing typical summer to decent fall. Can be more with extremes. But I dont chase the weather with my tune.
A few years ago I ran on back to back fall weekends at T&T only at PRP (at that time). I always have my weather meter out and guys like to chat about it. The first weekend day was nice and my weather station said it was very good air. The second weekend day seemed very much like the first one, but the pressure was actually a bunch lower. My car pretty much hit the numbers I calculated base on the different DA. A bunch of guys came looking for me after there first pass as they were all a couple tenths off on what seemed like the same conditions. They were happy, but a bit surprised that it was the atmospheric conditions for what seemed like similar days.
