Double adjustable rear coilover shocks #2394954
10/29/17 06:05 PM
10/29/17 06:05 PM
Penna
70satelliteguy Offline OP
Penna
Thinking about going from QA-1 Rear coilover single adjustables to the Qa-1 double adjustables.Are the QA-1's any good? Do you have to use double on the front also when using double rear?
Mike
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2395004
10/29/17 07:27 PM
10/29/17 07:27 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Viking. Same shock less $. I have on all 4 corners. Very happy.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2395030
10/29/17 08:53 PM
10/29/17 08:53 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Afco
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2395031
10/29/17 08:56 PM
10/29/17 08:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
How fast is the car?
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2395195
10/30/17 03:29 AM
10/30/17 03:29 AM
Cab_Burge Online work
Cab_Burge  Online Work
You get what you pay for work
if it is a fairly fast, mid tens in the 1/4 mile, I would look at the best D.A. shocks I could afford.
I really like the Strange double adjustable I had on my old pump gas Duster, they where 15.5 extended and around 7.0 inch fully compressed, I started with a 170 lb. spring and changed to a 150 and finally a 130 lb. springs up scope
Re: Double adjustable rear coilover shocks [Re: Cab_Burge] #2395933
10/31/17 10:40 AM
10/31/17 10:40 AM
Penna
Penna
Car is mid 9 sec car. Has 130 lb. springs and
" they where 15.5 extended and around 7.0 inch fully compressed"
How do I know which ones to get? They have a bunch of Ext/comp listed in Summit.
Thanks Mike
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2396095
10/31/17 03:25 PM
10/31/17 03:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Buy the BEST shock you can AFFORD!
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2396140
10/31/17 04:23 PM
10/31/17 04:23 PM
Call all the shock companies, Strange, Afco, Santuff, QA1 and so on, you would buy from and ask them for there opinions and recommendations and then decide twocents scope
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2396143
10/31/17 04:26 PM
10/31/17 04:26 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
That’s how I decided on my Vikings. A call to them was well worth my time.
Re: Double adjustable rear coilover shocks [Re: Al_Alguire] #2396329
10/31/17 10:26 PM
10/31/17 10:26 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Just got Menscers for mine.
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2396516
11/01/17 09:38 AM
11/01/17 09:38 AM
gregsdart Offline
gregsdart  Offline
Do you have ladder bars? Ladder bars need a VERY good, custom valved shock if you are running a lot of SLR or lots of torque, and I am guessing you have both.
Re: Double adjustable rear coilover shocks [Re: gregsdart] #2396567
11/01/17 11:31 AM
11/01/17 11:31 AM
Penna
Penna
Yes Greg. 36 in. ladder bars 572 motor at 3560 lbs.
Do I need to run doubles on front also if I put them on the rear?
Mike
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2396611
11/01/17 12:40 PM
11/01/17 12:40 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Doubles on the front let you control compression and rebound separate. I personally like to be able to do that.
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2397083
11/01/17 11:43 PM
11/01/17 11:43 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Mike
Similar to what I have now - I switched from QA1 sa to Afco da on all 4 corners. I still have had only a limited amount of testing but can say with these shocks I can see a change good/bad with every adjustment. I could not say that about the QA1's
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2397094
11/01/17 11:56 PM
11/01/17 11:56 PM
gregsdart Offline
gregsdart  Offline
In my case I needed double adjustable front shocks to handle the landing after a wheel stand. Better to be certain you bought the right shocks than to have to do it twice.
Re: Double adjustable rear coilover shocks [Re: gregsdart] #2397204
11/02/17 10:20 AM
11/02/17 10:20 AM
Penna
Penna
"In my case I needed double adjustable front shocks to handle the landing after a wheel stand."
__
My car does wheel stand. _Will DA shocks save my oilpan?
Mike______________________
Re: Double adjustable rear coilover shocks [Re: 70satelliteguy] #2397612
11/03/17 12:21 AM
11/03/17 12:21 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Mid 9 second horsepower @ 3560# with ladderbars. 3 speed? The cheapest shock I would consider is an Afco with Big Gun valving. I can't imagine any other sub $800/pair, off the shelf unit having a chance with that combination, unless it had the valving upgraded. And then they may not last long.
15.5" extended is a short shock. Does the car have adjustable shock mounts? I'd want to see a 17" shock like the 3850BG Afco on there at about 13.75 or 14" installed at ride height.
130# spring at that weight is awfully soft unless the car is really heavy on the nose. I assume the spring is wound way up to get ride height at any acceptable shock C-C length. We have guys that heavy with 150s and even 170s but not 130s. A 130 spring would maybe be OK if it had no power, no gear and a 4 link, maybe.
Re: Double adjustable rear coilover shocks [Re: CMcAllister] #2397660
11/03/17 01:51 AM
11/03/17 01:51 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Dude! iagree I love the AFCO shocks I put on my Challenger. At 2,800# with more than 50% on the rear I seriously needed the adjustment. Single adjustable, no bueno.
