Double adjustable rear coilover shocks
#2394954
10/29/17 06:05 PM
10/29/17 06:05 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Thinking about going from QA-1 Rear coilover single adjustables to the Qa-1 double adjustables.Are the QA-1's any good? Do you have to use double on the front also when using double rear? Mike
Re: Double adjustable rear coilover shocks
[Re: 70satelliteguy]
#2395004
10/29/17 07:27 PM
10/29/17 07:27 PM
Posts: 326 Alberta
Wookie316
Alberta
Viking. Same shock less $. I have on all 4 corners. Very happy.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
#2395195
10/30/17 03:29 AM
10/30/17 03:29 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
You get what you pay for if it is a fairly fast, mid tens in the 1/4 mile, I would look at the best D.A. shocks I could afford. I really like the Strange double adjustable I had on my old pump gas Duster, they where 15.5 extended and around 7.0 inch fully compressed, I started with a 170 lb. spring and changed to a 150 and finally a 130 lb. springs
#2396095
10/31/17 03:25 PM
10/31/17 03:25 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Buy the BEST shock you can AFFORD!
#2396140
10/31/17 04:23 PM
10/31/17 04:23 PM
Cab_Burge
Call all the shock companies, Strange, Afco, Santuff, QA1 and so on, you would buy from and ask them for there opinions and recommendations and then decide
#2396143
10/31/17 04:26 PM
10/31/17 04:26 PM
Posts: 326 Alberta
Wookie316
Alberta
That’s how I decided on my Vikings. A call to them was well worth my time.
#2396611
11/01/17 12:40 PM
11/01/17 12:40 PM
Posts: 326 Alberta
Wookie316
Alberta
Doubles on the front let you control compression and rebound separate. I personally like to be able to do that.
#2397083
11/01/17 11:43 PM
11/01/17 11:43 PM
Posts: 6,353 Aurora, Oh.
max_maniac
Aurora, Oh.
Yes Greg. 36 in. ladder bars 572 motor at 3560 lbs. Do I need to run doubles on front also if I put them on the rear? Mike Similar to what I have now - I switched from QA1 sa to Afco da on all 4 corners. I still have had only a limited amount of testing but can say with these shocks I can see a change good/bad with every adjustment. I could not say that about the QA1's
#2397612
11/03/17 12:21 AM
11/03/17 12:21 AM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Mid 9 second horsepower @ 3560# with ladderbars. 3 speed? The cheapest shock I would consider is an Afco with Big Gun valving. I can't imagine any other sub $800/pair, off the shelf unit having a chance with that combination, unless it had the valving upgraded. And then they may not last long.
15.5" extended is a short shock. Does the car have adjustable shock mounts? I'd want to see a 17" shock like the 3850BG Afco on there at about 13.75 or 14" installed at ride height.
130# spring at that weight is awfully soft unless the car is really heavy on the nose. I assume the spring is wound way up to get ride height at any acceptable shock C-C length. We have guys that heavy with 150s and even 170s but not 130s. A 130 spring would maybe be OK if it had no power, no gear and a 4 link, maybe.
