Re: W2 360 cam suggestions please!
[Re: R3DART]
#2394353
10/28/17 08:02 PM
10/28/17 08:02 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Mid/high-250's @.050, 108lsa........pick your favorite brand
[Re: R3DART]
#2394357
10/28/17 08:12 PM
10/28/17 08:12 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
I like and use comp Cams, for your deal I would look at their part #20-616-5 ,grind #fl272B-6 or the next bigger one Pt #20-635-5, grind #XTQ281S. I would install either one on a 101 to 103 intake lobe center and go have some fun All the SB I've built and help the owner race like the close LSA and advancing the intake lobe opening from 3 to 6 degrees closer to TDC from straight up As far as the carb size and part numbers your on your own with the Eddys If you had access to a pair of Holley 1850 I would use those in a heart beat, or maybe a pair of Holley 600 or 650 CFM D.P. I'm a drag race guy, so keep that in mind
[Re: R3DART]
#2394362
10/28/17 08:30 PM
10/28/17 08:30 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
No mention at all of what convertor you will use, nor expected compression. Without those, no way to spec a cam
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2394373
10/28/17 08:47 PM
10/28/17 08:47 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Heavily ported doesn’t mean dog poop without flow numbers
[Re: R3DART]
#2394412
10/28/17 10:17 PM
10/28/17 10:17 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why I asked is although the W2 is and can be a fantastic head it peaks funny. 260@.450 and drops like a rock. Proper work and it’s 300 plus easily
[Re: R3DART]
#2394417
10/28/17 10:28 PM
10/28/17 10:28 PM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
R3DART,
i'm in the process of building a stock stroke 360 with W2 heads. my heads were ported by Jesse Robinson known as RAMM on this site.. they flow 286 cfm.
i'm going to run a solid flat tappet cam. Hughes Engines grind #, STL6468AS. 615/621 lift with 264/268 dur @ .050.
i will use a Victor 340 single plane intake. compression will be at 13.1.
i have used a holley pro dominator tunnel ram in 2 different builds. 360'' and a 440'' SBM stroker. i ran 2 650 holleys.
[Re: scottb]
#2394523
10/29/17 01:04 AM
10/29/17 01:04 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Now you see why all the great people who used to post on here stopped due to all the BS that goes on here he was asking for a little help and all you want to do is give him some bs story about flow numbers like he said there are alot of 340 360 W2 motors out there id run something in the mid 250 intake low 260 exhaust worked great on my old W2 setup or something like Dons 360 260- 266 Howards cam Your right and I’m sorry. I will never try to help again. Pick up the slack for use please.
[Re: scottb]
#2394529
10/29/17 01:16 AM
10/29/17 01:16 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Now you see why all the great people who used to post on here stopped due to all the BS that goes on here he was asking for a little help and all you want to do is give him some bs story about flow numbers like he said there are alot of 340 360 W2 motors out there id run something in the mid 250 intake low 260 exhaust worked great on my old W2 setup or something like Dons 360 260- 266 Howards cam The more I think about it Scott I will give myself a short vacation. Now I’m kinda sorry I grabbed those Summit discount coupons this week at the Halloween Classic for our members. If anyone needs one check out some other mopar sites or Yellowbullet. Maybe Scott will contribute some
[Re: R3DART]
#2395037
10/29/17 09:04 PM
10/29/17 09:04 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Hi folks. I am bolting together some parts I have accumulated through the years. This is going to be a budget build utilizing as much of the shelves in my garage as possible. I am starting with stock stroke 360, not looking to build a stroker as the short block is very low miles wilt decent parts.
What I have: stock stroke 360 w/ flat tops Heavily ported W2’s Holley Pro dominator tunnel ram
What I need help with: camshaft (thinking solid flat, looking for suggestions) carburetors (thinking eddy’s, again open to suggestions on size and make)
Engine will end up in an A-Body, 3.91 gears and auto.
I would like to go solid flat tappet for cam.
Basically looking to build an old school budget street bruiser that will see the odd day at the track.
Thanks in advance! If the heads work really good, the TR will push your rpm range up quite high...and unless the valves your using are really lightweight, you may run into high rpm problems (above 7200rpm). Yes you can run higher pressures, up to a point though...just alot going on with poor tappet angle, largely offset rockers and heavy valve train. Solid roller would be my recommendation...is this on pump gas? If so, then solid FT might work as rpm peak will be a bit lower with lower compression.
Brian Hafliger
[Re: R3DART]
#2395098
10/29/17 11:04 PM
10/29/17 11:04 PM
Posts: 4,457 Washington
madscientist
Washington
Brian, thank you for the response. What you are saying makes sense. I really would like to put that old tunnel ram to use but looks like just to much of a mismatch for what the bottom end will take. The heads came with a port matched strip dominator. Looks like the TR will stay on the shelf for a while. Yes, it is going to be a pump gas engine. Open chamber W2’s and flat tops are what I have. Buy the correct cam for a TR and it won't turn any more RPM than it will with a single 4. And the TR will make more bottom and mid power.
[Re: R3DART]
#2395109
10/29/17 11:25 PM
10/29/17 11:25 PM
Posts: 815 Alexandria, NJ
WayneM
Alexandria, NJ
I have Non worked W2 econos on a 10.5 340, and it's pretty happy with this old purple shaft, "653" last of the part #. It measures .528/284/112. Summit still has it but it's expensive. I ran across it just today while helping pick a mild SB cam for a friend. This cam is happy with a 10" converter and 4.30's. Its been running 12.30's for a couple of decades now.
2014 Durango R/T 2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed 1998 Dodge Durango SLT 5.2 1971 Plymouth Duster- <<<<<MOPAR SPOKEN HERE>>>>>
[Re: madscientist]
#2395139
10/30/17 12:16 AM
10/30/17 12:16 AM
Posts: 1,051 The Great White North
RAMM
[quote=madscientist Buy the correct cam for a TR and it won't turn any more RPM than it will with a single 4. And the TR will make more bottom and mid power. [/quote]
Was about to post something similar but more exact. Cam does not really dictate max rpm power potential at all. That is all in the induction. Everytime I've used a TR it has lowered RPM peak HP and torque comes up across the board. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
