Need a oiling schematic for Indy block #2389836
10/19/17 02:25 PM
10/19/17 02:25 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
We are on to something. I need a schematic for all the holes the the oil pump intersects with.
Re: Need a oiling schematic for Indy block [Re: Dragula] #2390011
10/19/17 08:48 PM
10/19/17 08:48 PM
Dragula Offline OP
Dragula  Offline OP
Ok...can some map out the holes in the block where the pump attaches?
Re: Need a oiling schematic for Indy block [Re: Dragula] #2390472
10/20/17 08:32 PM
10/20/17 08:32 PM
Dragula Offline OP
Dragula  Offline OP
The amount of help on here is stunning...
Re: Need a oiling schematic for Indy block [Re: Dragula] #2390511
10/20/17 09:31 PM
10/20/17 09:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Half the guys don’t build their own engines and out of the other half how many guys have Indy blocks. Limited crowd you are talking to
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need a oiling schematic for Indy block [Re: Dragula] #2390516
10/20/17 09:44 PM
10/20/17 09:44 PM
Superfreak
Superfreak
I'm sure if you contact BG they would help you out. Bob is a pretty outstanding guy.
Re: Need a oiling schematic for Indy block [Re: Dragula] #2390580
10/20/17 11:23 PM
10/20/17 11:23 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've never seen a flow chart for the oiling system on an Indy block. Don't even know if one exists.
[image][/image]
Re: Need a oiling schematic for Indy block [Re: Dragula] #2390581
10/20/17 11:25 PM
10/20/17 11:25 PM
sgcuda Offline
sgcuda  Offline
Mine is on an engine stand. Can I help with something? RB solid block, if it matters.
[image][/image]
Re: Need a oiling schematic for Indy block [Re: Dragula] #2390669
10/21/17 03:12 AM
10/21/17 03:12 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I have one on the floor. It's pretty much like factory stuff, except no internal pick up. Instead, there is a provision in front of the block for a pick up hose. From the pump the oil goes to passenger side and from there outside of the lifter bores, to the rear of the block and mains. Can check today if you can explain what you are looking for so that I understand it.
Plynouth VIP '67 TT IC EFI
Re: Need a oiling schematic for Indy block [Re: Dragula] #2390672
10/21/17 03:21 AM
10/21/17 03:21 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I don't recall ever seeing one either. I don't have any way to make one either. Maybe if you ask a specific question we can help but it is pretty much as jyrki describes..
Re: Need a oiling schematic for Indy block [Re: Dragula] #2396535
11/01/17 10:22 AM
11/01/17 10:22 AM
an8sec70cuda Offline
Yall ever figure out why this thing won't build oil pressure?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Need a oiling schematic for Indy block [Re: an8sec70cuda] #2396914
11/01/17 08:32 PM
11/01/17 08:32 PM
Dragula Offline OP
Dragula  Offline OP
Yup....Some worn out/bad fittings and hose it seems. I need to order parts before I know if there is anything else.
