Re: Need a oiling schematic for Indy block
[Re: Dragula]
#2390511
10/20/17 09:31 PM
10/20/17 09:31 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Half the guys don’t build their own engines and out of the other half how many guys have Indy blocks. Limited crowd you are talking to
[Re: Dragula]
#2390516
10/20/17 09:44 PM
10/20/17 09:44 PM
Superfreak
Superfreak
I'm sure if you contact BG they would help you out. Bob is a pretty outstanding guy.
[Re: Dragula]
#2390669
10/21/17 03:12 AM
10/21/17 03:12 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
I have one on the floor. It's pretty much like factory stuff, except no internal pick up. Instead, there is a provision in front of the block for a pick up hose. From the pump the oil goes to passenger side and from there outside of the lifter bores, to the rear of the block and mains. Can check today if you can explain what you are looking for so that I understand it.
Plynouth VIP '67 TT IC EFI
[Re: Dragula]
#2390672
10/21/17 03:21 AM
10/21/17 03:21 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I don't recall ever seeing one either. I don't have any way to make one either. Maybe if you ask a specific question we can help but it is pretty much as jyrki describes..
[Re: Dragula]
#2396535
11/01/17 10:22 AM
11/01/17 10:22 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Yall ever figure out why this thing won't build oil pressure?
[Re: an8sec70cuda]
#2396914
11/01/17 08:32 PM
11/01/17 08:32 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
Yup....Some worn out/bad fittings and hose it seems. I need to order parts before I know if there is anything else.
