Carburetor spacers for heat #2390620
10/21/17 12:35 AM
10/21/17 12:35 AM
CA.
RAY1969CARS Offline OP
CA.
Hi guys what is the minimum thickness of Phenolic Spacer you should put under your carburetor to stop transfer of heat
thanks Mopar or no car
Re: Carburetor spacers for heat [Re: RAY1969CARS] #2390633
10/21/17 01:29 AM
10/21/17 01:29 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Probably even 1/4" will help alot
Re: Carburetor spacers for heat [Re: sixpackgut] #2390643
10/21/17 01:53 AM
10/21/17 01:53 AM
Kirkland, Washington
Pacnorthcuda Offline
I agree. Additional thickness is only going to gain decreasing gains. Other concerns such as air cleaner clearance and linkage come into play..
And the discussion of power with an intake riser is another thread.
Re: Carburetor spacers for heat [Re: RAY1969CARS] #2390649
10/21/17 02:10 AM
10/21/17 02:10 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Check out a company called coolcarb technologies. www.coolcarb.com
Not sure of any power gains but they should help with fuel temps inside the carb.
Todd
Re: Carburetor spacers for heat [Re: RAY1969CARS] #2390661
10/21/17 02:57 AM
10/21/17 02:57 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would say at least a 1/4". You can see mine here as it looks to be an inch. Its been on the car so long I forgot what size it was. And it made a ton of difference to help stop the fuel from boiling in the carb bowls. Ron
Re: Carburetor spacers for heat [Re: RAY1969CARS] #2390668
10/21/17 03:09 AM
10/21/17 03:09 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We tested this stuff years ago. Found hardwood actually worked better than phenolic spacers did. We settled on 1/2" spacers. But this was years ago for sure. Also those heat shields have been around for years, in a pump gas street car with a tight engine compartment they wore worth something I would imagine. Will definitely help with boiling fuel in the bowls for sure.
Re: Carburetor spacers for heat [Re: Al_Alguire] #2390681
10/21/17 04:00 AM
10/21/17 04:00 AM
CA.
CA.
Right on I'm going to try 1/4 thanks
Re: Carburetor spacers for heat [Re: RAY1969CARS] #2390749
10/21/17 11:49 AM
10/21/17 11:49 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I don't know what the minimum thickness is but I made up a 2 "one out of 1/2 " Baltic birch 9 ply plywood for the race car. Carb was no hotter than the fender, the manifold-engine was to hot to touch. I was still able to close the hood with tall intake and that spacer and air cleaner (383). Wood is one of the best insulators also.
Re: Carburetor spacers for heat [Re: cudaman1969] #2390764
10/21/17 12:22 PM
10/21/17 12:22 PM
moparx Offline
moparx  Offline
does anyone make a phenolic adapter for a spread bore to square bore application ?
beer
Re: Carburetor spacers for heat [Re: RAY1969CARS] #2390782
10/21/17 12:47 PM
10/21/17 12:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If you really wanted to isolate the carb from the manifold you would also need to use nylon or fiber washers under the carb nuts. Probably minimal gains but thats one less spot to transfer heat.
When I had a carb my vapor lock problems were rare even with a stock hood, but it seemed to be underhood temp as opposed to engine temp that got them. I have an old trans temp gauge hanging near the master cylinder. When it reads over 180* is when vapor lock problems seem to start. In a stock engine compartment full of hot air I am not sure you can make much of a difference. I never had room for a spacer so I was never able to try.
68 Barracuda Formula S 340
Re: Carburetor spacers for heat [Re: RAY1969CARS] #2390792
10/21/17 01:18 PM
10/21/17 01:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I try and use a 1/2 minimum or more if possible according to the type of manifold, rpm range and of course space available.........I run a 1/2" 4 hole under my Dommy..............
Re: Carburetor spacers for heat [Re: sasquatch] #2390796
10/21/17 01:23 PM
10/21/17 01:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Todd
Not too impressed w/a 100+ degree carb and I posted a video on VB where my engine was around 160 the intake 120 ish and my carb was 71 degrees after sitting w/just a 1/2" wooden spacer............ thumbs
Re: Carburetor spacers for heat [Re: Thumperdart] #2390799
10/21/17 01:26 PM
10/21/17 01:26 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
The best way to keep a carb running nice and cool is a bypass fuel regulator after the carb so cool fuel is always available. Even with this setup, the secondary fuel bowl can get really hot on those 100 mile drives between fill ups
Re: Carburetor spacers for heat [Re: sixpackgut] #2390811
10/21/17 01:49 PM
10/21/17 01:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agree that a TRUE return is best and my pump just returns straight into the cell but wonder if I can mod it and will call Magna-fuel and ask em for giggles............ beer
Re: Carburetor spacers for heat [Re: sixpackgut] #2390825
10/21/17 02:07 PM
10/21/17 02:07 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats true. I have got away with my deadhead setup but I have a return type regulator I would like to install. Course I have a stock tank and will have to find a sending unit with a port or take mine out and make a port for a return line. I have also heard wood is the best isolator to use and I may switch to wood soon. Ron
Re: Carburetor spacers for heat [Re: sasquatch] #2391452
10/22/17 09:40 PM
10/22/17 09:40 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Todd
I’m going to give that a try.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
