Re: Carburetor spacers for heat
[Re: RAY1969CARS]
#2390633
10/21/17 01:29 AM
10/21/17 01:29 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Probably even 1/4" will help alot
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2390643
10/21/17 01:53 AM
10/21/17 01:53 AM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Probably even 1/4" will help alot I agree. Additional thickness is only going to gain decreasing gains. Other concerns such as air cleaner clearance and linkage come into play.. And the discussion of power with an intake riser is another thread.
[Re: RAY1969CARS]
#2390668
10/21/17 03:09 AM
10/21/17 03:09 AM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
We tested this stuff years ago. Found hardwood actually worked better than phenolic spacers did. We settled on 1/2" spacers. But this was years ago for sure. Also those heat shields have been around for years, in a pump gas street car with a tight engine compartment they wore worth something I would imagine. Will definitely help with boiling fuel in the bowls for sure.
[Re: RAY1969CARS]
#2390782
10/21/17 12:47 PM
10/21/17 12:47 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
If you really wanted to isolate the carb from the manifold you would also need to use nylon or fiber washers under the carb nuts. Probably minimal gains but thats one less spot to transfer heat.
When I had a carb my vapor lock problems were rare even with a stock hood, but it seemed to be underhood temp as opposed to engine temp that got them. I have an old trans temp gauge hanging near the master cylinder. When it reads over 180* is when vapor lock problems seem to start. In a stock engine compartment full of hot air I am not sure you can make much of a difference. I never had room for a spacer so I was never able to try.
68 Barracuda Formula S 340
[Re: RAY1969CARS]
#2390792
10/21/17 01:18 PM
10/21/17 01:18 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I try and use a 1/2 minimum or more if possible according to the type of manifold, rpm range and of course space available.........I run a 1/2" 4 hole under my Dommy..............
[Re: sasquatch]
#2390796
10/21/17 01:23 PM
10/21/17 01:23 PM
Thumperdart
State of confusion
Check out a company called coolcarb technologies. www.coolcarb.comNot sure of any power gains but they should help with fuel temps inside the carb. Todd Not too impressed w/a 100+ degree carb and I posted a video on VB where my engine was around 160 the intake 120 ish and my carb was 71 degrees after sitting w/just a 1/2" wooden spacer............
[Re: Thumperdart]
#2390799
10/21/17 01:26 PM
10/21/17 01:26 PM
sixpackgut
Charleston
The best way to keep a carb running nice and cool is a bypass fuel regulator after the carb so cool fuel is always available. Even with this setup, the secondary fuel bowl can get really hot on those 100 mile drives between fill ups
[Re: sixpackgut]
#2390825
10/21/17 02:07 PM
10/21/17 02:07 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
The best way to keep a carb running nice and cool is a bypass fuel regulator after the carb so cool fuel is always available. Even with this setup, the secondary fuel bowl can get really hot on those 100 mile drives between fill ups Thats true. I have got away with my deadhead setup but I have a return type regulator I would like to install. Course I have a stock tank and will have to find a sending unit with a port or take mine out and make a port for a return line. I have also heard wood is the best isolator to use and I may switch to wood soon. Ron
[Re: sasquatch]
#2391452
10/22/17 09:40 PM
10/22/17 09:40 PM
Posts: 16,472 On the run…
BloFish
On the run…
Check out a company called coolcarb technologies. www.coolcarb.comNot sure of any power gains but they should help with fuel temps inside the carb. Todd I’m going to give that a try.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
