BB 727 rebuild kits? #238677
02/28/09 09:03 AM
02/28/09 09:03 AM
KY
juicedcuda Offline OP
KY
Who makes the best rebuild kits for the 727? I hear all this talk about different color clutches and what not, so what is the best one?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: BB 727 rebuild kits? [Re: juicedcuda] #238678
02/28/09 09:09 AM
02/28/09 09:09 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
An easy way to simplify your life is to just call John at CRT. There is nothing easier and better than to talk to a Mopar friendly technician.
http://coperacingtrans.com/
Re: BB 727 rebuild kits? [Re: juicedcuda] #238679
02/28/09 10:26 AM
02/28/09 10:26 AM
NC
440Jim Offline
440Jim  Offline
NC
I buy the parts I want individually, but CRT is your one stop shopping center to make it easy and be sure of quality parts and advice.
What you need depends on your application, but these are some of the things I like to see in a race 727:
  • babbit front bushing (converter)
  • Bushing kit for the rest (need drivers to install)
  • New thrust washers (3 or 4 tab depending on planetaries, or even 5)
  • Teflon reaction support rings (for high pressure valve bodies)
  • Stock type rear clutch frictions and steels
  • High quality front frictions with oil grooves (Alto Red Eagle, Raybestos HD, High Energy)
  • Heavy duty rear servo retainer (0.070" thick)
  • Billet rear servo for LBA valve bodies, heavier spring
  • Solid (ridgid) front band, red lining (rather than flex band)
  • Bronze thrust washer between output and input shafts (stock is a fiber material)
  • A good quality pan gasket (rather than a cheap cork one)
  • The rest of the sealing rings, rubber seals, gaskets are pretty much standard stuff
There are a couple other places that a teflon type ring is available such as the front servo, and the small rings on the input shaft.
Re: BB 727 rebuild kits? [Re: juicedcuda] #238680
02/28/09 11:03 AM
02/28/09 11:03 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We have been using the Turbo Action "Tranz Box" kits for many years with no problems.
www.turboaction.com
Nautilus Racing-
Re: BB 727 rebuild kits? [Re: dc426] #238681
02/28/09 11:17 AM
02/28/09 11:17 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
John has taken real good care of me.
Re: BB 727 rebuild kits? [Re: 440Jim] #238682
02/28/09 06:04 PM
02/28/09 06:04 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Do you care-to-share where you get those individual parts from ?
Re: BB 727 rebuild kits? [Re: dOrk !] #238683
02/28/09 06:15 PM
02/28/09 06:15 PM
NC
440Jim Offline
440Jim  Offline
NC
Re: BB 727 rebuild kits? [Re: juicedcuda] #238684
02/28/09 07:26 PM
02/28/09 07:26 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
I have had very good service dealing with Rick at A&A. He will put together whatever you need for a kit.
Garth
