Slicks
#2386770
10/13/17 11:44 AM
10/13/17 11:44 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I mounted a set of M/T 10.5w with no tube and blued to the bead.At the track last week they moved over an inch.Thought when glued they move up to a 1/2 inch and stop Rims not screwed..........
Re: Slicks
[Re: hemi-itis]
#2386795
10/13/17 12:16 PM
10/13/17 12:16 PM
Posts: 20,162 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I mounted a set of M/T 10.5w with no tube and blued to the bead.At the track last week they moved over an inch.Thought when glued they move up to a 1/2 inch and stop Rims not screwed.......... A lot of guys don't go about this right. The tires when new have a "mold compound" on them to help release when the are built. I take a day and apply my Dawn dish soap to the entire inside of the slicks and let dry (2 coats). I then clean the slick sealing lip carefully with lacquer thinner and gently sand it with red scuff pads and clean again with thinner. I carefully clean the wheel lip too. I use brush on High tac and "no soap when mounting. This process works GREAT for me.
Re: Slicks
[Re: hemi-itis]
#2386814
10/13/17 12:36 PM
10/13/17 12:36 PM
Posts: 10,021 MN
JERICOGTX
MN
I thought you bought beadlocks?
69 GTX
68 Road Runner
Re: Slicks
[Re: hemi-itis]
#2387152
10/14/17 12:28 AM
10/14/17 12:28 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Permatex hi-tack here. Just like Doug said..... moved a tad the 1st time out. Locked down since.
Re: Slicks
[Re: actionange]
#2387154
10/14/17 12:29 AM
10/14/17 12:29 AM
hemi-itis
I had a set of Hoosiers do that to me once with tubes installed. I added 8 rim screws per side. All better. So how'd you do Al? Any 8 second time slips? Close,but the weatherman said not today.The explosion made for an interesting day
Re: Slicks
[Re: Dave Hall]
#2387346
10/14/17 02:23 PM
10/14/17 02:23 PM
hemi-itis
Hopefully we are looking at (top pic) passenger side? (Bottom pic) drivers side? BTW those look like used tires? Dave,I boguht them new and might have 23 passes on them.
Re: Slicks
[Re: hemi-itis]
#2387369
10/14/17 03:21 PM
10/14/17 03:21 PM
Posts: 9,826 MI, usa
dvw
MI, usa
I rotate every 30 passes or so. They haven't moved after the first passes.car has been 1.240@3350lbs Doug
Re: Slicks
[Re: hemi-itis]
#2387446
10/14/17 07:10 PM
10/14/17 07:10 PM
crabman173
crabman173
Screw em! Drag cars need it--If it is a drag car with slicks forget about your pretty wheels and drill them correctly screw them and forget it MT website had great tech how to on doing job right --in low powered car ( like anything except turbo big NOS monsters ) 8 screws are fine but more power equals more screws like MT says to prevent tire shake on monster HP stuff Slow motion videos have shown that more screws are better for BIG HP stuff what we usually run 8 per side is plenty and has worked for me for decades Drill screw hole on fat side--use a screw to "tap" the holes first--keep a fresh new screw during this process and it will keep from breaking one off --also that is where a tad larger than spec'd on the hole size really works to your advantage--screw does not have to be so darn tight in wheel at all
Re: Slicks
[Re: hemi-itis]
#2387482
10/14/17 09:33 PM
10/14/17 09:33 PM
hemi-itis
I respect what your sayin Crabby,but guys ALOT faster than my heap are glued without issues.........
Re: Slicks
[Re: pittsburghracer]
#2388200
10/16/17 03:11 PM
10/16/17 03:11 PM
crabman173
crabman173
I mounted a set of M/T 10.5w with no tube and blued to the bead.At the track last week they moved over an inch.Thought when glued they move up to a 1/2 inch and stop Rims not screwed.......... A lot of guys don't go about this right. The tires when new have a "mold compound" on them to help release when the are built. I take a day and apply my Dawn dish soap to the entire inside of the slicks and let dry (2 coats). I then clean the slick sealing lip carefully with lacquer thinner and gently sand it with red scuff pads and clean again with thinner. I carefully clean the wheel lip too. I use brush on High tac and "no soap when mounting. This process works GREAT for me. Me likey I will try this next time I have a set of real vintage magnesiums I will not drill ever--way to valuable so good plan here Thanks guys!!
