Slicks #2386770
10/13/17 11:44 AM
10/13/17 11:44 AM
Great Neck,LI,new york
hemi-itis Offline OP
I mounted a set of M/T 10.5w with no tube and blued to the bead.At the track last week they moved over an inch.Thought when glued they move up to a 1/2 inch and stop shruggy
Rims not screwed..........
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Slicks [Re: hemi-itis] #2386795
10/13/17 12:16 PM
10/13/17 12:16 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
A lot of guys don't go about this right. The tires when new have a "mold compound" on them to help release when the are built. I take a day and apply my Dawn dish soap to the entire inside of the slicks and let dry (2 coats). I then clean the slick sealing lip carefully with lacquer thinner and gently sand it with red scuff pads and clean again with thinner. I carefully clean the wheel lip too. I use brush on High tac and "no soap when mounting. This process works GREAT for me.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Slicks [Re: hemi-itis] #2386814
10/13/17 12:36 PM
10/13/17 12:36 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I thought you bought beadlocks?
69 GTX 68 Road Runner
Re: Slicks [Re: hemi-itis] #2386943
10/13/17 04:58 PM
10/13/17 04:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine are glued with purple Permatex. They moved about 1/4" the first outing. Haven't moved since, 150 passes.
Doug
Re: Slicks [Re: hemi-itis] #2387131
10/13/17 11:29 PM
10/13/17 11:29 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I had a set of Hoosiers do that to me once with tubes installed. I added 8 rim screws per side.
All better.
So how'd you do Al? Any 8 second time slips?
Re: Slicks [Re: JERICOGTX] #2387142
10/14/17 12:07 AM
10/14/17 12:07 AM
I did,they have 16.5x31 ET streets on them.
Re: Slicks [Re: hemi-itis] #2387152
10/14/17 12:28 AM
10/14/17 12:28 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Permatex hi-tack here. Just like Doug said..... moved a tad the 1st time out. Locked down since.
Re: Slicks [Re: actionange] #2387154
10/14/17 12:29 AM
10/14/17 12:29 AM
All better.
Close,but the weatherman said not today.The explosion made for an interesting day shock
Re: Slicks [Re: hemi-itis] #2387158
10/14/17 12:44 AM
10/14/17 12:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My brother has a small amount of glue on his. He said the same as some of you that his moved about 1/4 or a bit more the first time out with the new slicks and has not moved any more. I also dont run tubes and to be honest mine are not glued and I have never checked them to see if they moved any. All I can say is they dont lose any air and have never gone flat. Ron
Re: Slicks [Re: hemi-itis] #2387206
10/14/17 03:43 AM
10/14/17 03:43 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Hopefully we are looking at (top pic) passenger side? (Bottom pic) drivers side? grin
BTW those look like used tires?
Re: Slicks [Re: hemi-itis] #2387336
10/14/17 01:56 PM
10/14/17 01:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would rotate from side to side on non directional slicks with no screws after every race for two or three times and the tires would stop moving after that scope up
Re: Slicks [Re: Dave Hall] #2387346
10/14/17 02:23 PM
10/14/17 02:23 PM
Dave,I boguht them new and might have 23 passes on them.
Re: Slicks [Re: Cab_Burge] #2387347
10/14/17 02:25 PM
10/14/17 02:25 PM
Kinda move then in both directions 'till they stop??One of my friends said his moved 7 inches before they stopped.........
Re: Slicks [Re: hemi-itis] #2387369
10/14/17 03:21 PM
10/14/17 03:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I rotate every 30 passes or so. They haven't moved after the first passes.car has been 1.240@3350lbs
Doug
Re: Slicks [Re: hemi-itis] #2387446
10/14/17 07:10 PM
10/14/17 07:10 PM
crabman173
crabman173
Screw em!
Drag cars need it--If it is a drag car with slicks forget about your pretty wheels and drill them correctly screw them and forget it
MT website had great tech how to on doing job right --in low powered car ( like anything except turbo big NOS monsters ) 8 screws are fine but more power equals more screws like MT says to prevent tire shake on monster HP stuff
Slow motion videos have shown that more screws are better for BIG HP stuff
what we usually run 8 per side is plenty and has worked for me for decades
Drill screw hole on fat side--use a screw to "tap" the holes first--keep a fresh new screw during this process and it will keep from breaking one off --also that is where a tad larger than spec'd on the hole size really works to your advantage--screw does not have to be so darn tight in wheel at all
Re: Slicks [Re: hemi-itis] #2387482
10/14/17 09:33 PM
10/14/17 09:33 PM
I respect what your sayin Crabby,but guys ALOT faster than my heap are glued without issues.........
Re: Slicks [Re: hemi-itis] #2387485
10/14/17 09:43 PM
10/14/17 09:43 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The good thing is the car is working. I wouldn't worry about it too much as it moved very little and probably locked on there. Try upping the tire pressure a little bit and maybe roll out of the water a little sooner. The yellow letters look to be a bit more than 23 passes. I believe you though and maybe the burnout is a bit excessive. Burnouts are fun though and I love doing them!
Re: Slicks [Re: hemi-itis] #2388176
10/16/17 02:33 PM
10/16/17 02:33 PM
Will switch sides next time out and see what happens.
Re: Slicks [Re: pittsburghracer] #2388200
10/16/17 03:11 PM
10/16/17 03:11 PM
crabman173
crabman173
Me likey I will try this next time I have a set of real vintage magnesiums I will not drill ever--way to valuable so good plan here Thanks guys!!
Re: Slicks [Re: hemi-itis] #2388216
10/16/17 03:46 PM
10/16/17 03:46 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The mold release agent is readily apparent on a new tire. Pittsburgh has it right. I don't think it would hurt to go over the inner wheel lip with some scotch brite if so inclined on an aluminum wheel. Otherwise screw 'em or get a set of beadlocks.
