How do I remove windshield? #2384567
10/09/17 05:50 PM
10/09/17 05:50 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
What's the best at-home method for removing the front windshield from '73 barracuda?
thanks !
Re: How do I remove windshield? [Re: lostdog] #2384573
10/09/17 05:55 PM
10/09/17 05:55 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The original window gaskets on my car were hard as a rock so I carefully cut them with a utility knife to get the glass to come out.
Re: How do I remove windshield? [Re: Neil] #2384576
10/09/17 06:03 PM
10/09/17 06:03 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I cannot tell if this is held in with a molded rubber gasket or is it the adhesive that's applied from a tube? My windshield is badly cracked so I am not trying to save it. I need to slip a cutting tool between the glass and adhesive/gasket ?
Re: How do I remove windshield? [Re: lostdog] #2384595
10/09/17 06:19 PM
10/09/17 06:19 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I'm not familiar with the E bodies, but all the others from that era were a rubber gasket as far as I know.
I also used the knife for many years.
I now have the tool made for windshield removal.
It's simply a handle with a sharp angeld blade at one end and a handle on a cable at the other end.
Insert the blade and carefully pull it around the glass.
Viola. The glass can now easily be removed.
It is very helpful.
I have mechanical Aptitude.
I can screw up anything.
Re: How do I remove windshield? [Re: bboogieart] #2384601
10/09/17 06:25 PM
10/09/17 06:25 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
It is very helpful.
Great ! I was thinking I would use that tool, but wasn't sure how the glass comes out. So I take it the gasket is not designed to be reused but instead replaced with new glass? I already have too much to fix on this car and am trying to avoid making more work for myself
Re: How do I remove windshield? [Re: lostdog] #2384604
10/09/17 06:29 PM
10/09/17 06:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
thanks !
E body windshields and rear windows as well are "glued" in, no gasket, use the wire cord and or hot blade method to cut it out
Re: How do I remove windshield? [Re: bboogieart] #2384606
10/09/17 06:31 PM
10/09/17 06:31 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
K Tool International
Part number# KTI-70540
Re: How do I remove windshield? [Re: lostdog] #2384608
10/09/17 06:32 PM
10/09/17 06:32 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Correct
Re: How do I remove windshield? [Re: DAYCLONA] #2384611
10/09/17 06:35 PM
10/09/17 06:35 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted By DAYCLONA
E body windshields and rear windows as well are "glued" in, no gasket, use the wire cord method to cut it out
Well we live and learn. up
Re: How do I remove windshield? [Re: lostdog] #2384613
10/09/17 06:36 PM
10/09/17 06:36 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Thanks, guys !
I am taking the glass out because I am prepping to replace the firewall. Fun fun!
Re: How do I remove windshield? [Re: lostdog] #2384614
10/09/17 06:39 PM
10/09/17 06:39 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Big project, for me anyways.
Can't wait to see the end result. beer
Re: How do I remove windshield? [Re: bboogieart] #2384726
10/09/17 09:25 PM
10/09/17 09:25 PM
IN
ahy Offline
ahy  Offline
IN
Getting the old glass out with ancient adhesive without cracking it is hard. An experienced shop did mine. The front cracked and new windshield required. The back did not crack and was re-used. I now wish the back had cracked also... the 40 YE glass with some scars is not the best.
Re: How do I remove windshield? [Re: lostdog] #2384727
10/09/17 09:30 PM
10/09/17 09:30 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
harbor freight windshield tool.
this tool comes with braided wire so it will cut thru the sealant faster.
1 guy can use it to remove glass. if you do it with 2 guys it will work much better.
https://www.harborfreight.com/professional-windshield-removal-kit-96339.html
the cold knife listed several times requires some skill to use without breakage.
if you really want to save the glass call a pro that uses one of these windshield tools.
https://www.youtube.com/watch?v=rYpzD-VBq0I
several manufacturers make similar tools.
the glass co that our shop uses has one. they have removed several hundeds windshields without breakage that are installed with urethane.
perception is 90% of reality
Re: How do I remove windshield? [Re: lostdog] #2384742
10/09/17 09:49 PM
10/09/17 09:49 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
I believe the OP stated that the glass is already cracked, so use the cold knife, it will be the easiest..
Someone stated the WS broke, but the back glass came out.. Different types of glass, normal for all the tempered pieces to make it, while the WS will usually break being NON tempered.......
Re: How do I remove windshield? [Re: lostdog] #2385703
10/11/17 04:29 PM
10/11/17 04:29 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
After it was confirmed from you guys that the windshield is set with adhesive, I took a guitar string, slid it under the windshield and sawed it back and forth around the glass. I had it out in about 15 minutes and in ONE piece Thanks, guys!
Re: How do I remove windshield? [Re: lostdog] #2385842
10/11/17 07:58 PM
10/11/17 07:58 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
