How do I remove windshield?
#2384567
10/09/17 05:50 PM
10/09/17 05:50 PM
Posts: 361 mississippi
lostdog
mississippi
What's the best at-home method for removing the front windshield from '73 barracuda?
thanks !
Re: How do I remove windshield?
[Re: lostdog]
#2384595
10/09/17 06:19 PM
10/09/17 06:19 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I'm not familiar with the E bodies, but all the others from that era were a rubber gasket as far as I know. I also used the knife for many years. I now have the tool made for windshield removal. It's simply a handle with a sharp angeld blade at one end and a handle on a cable at the other end. Insert the blade and carefully pull it around the glass. Viola. The glass can now easily be removed. It is very helpful.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2384601
10/09/17 06:25 PM
10/09/17 06:25 PM
lostdog
mississippi
I'm not familiar with the E bodies, but all the others from that era were a rubber gasket as far as I know. I also used the knife for many years. I now have the tool made for windshield removal. It's simply a handle with a sharp angeld blade at one end and a handle on a cable at the other end. Insert the blade and carefully pull it around the glass. Viola. The glass can now easily be removed. It is very helpful. Great ! I was thinking I would use that tool, but wasn't sure how the glass comes out. So I take it the gasket is not designed to be reused but instead replaced with new glass? I already have too much to fix on this car and am trying to avoid making more work for myself
[Re: lostdog]
#2384604
10/09/17 06:29 PM
10/09/17 06:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
thanks ! E body windshields and rear windows as well are "glued" in, no gasket, use the wire cord and or hot blade method to cut it out
[Re: lostdog]
#2384608
10/09/17 06:32 PM
10/09/17 06:32 PM
bboogieart
Lost and Spaced
Correct
[Re: DAYCLONA]
#2384611
10/09/17 06:35 PM
10/09/17 06:35 PM
bboogieart
Lost and Spaced
E body windshields and rear windows as well are "glued" in, no gasket, use the wire cord method to cut it out Well we live and learn.
[Re: lostdog]
#2384614
10/09/17 06:39 PM
10/09/17 06:39 PM
bboogieart
Lost and Spaced
Big project, for me anyways. Can't wait to see the end result.
[Re: lostdog]
#2384727
10/09/17 09:30 PM
10/09/17 09:30 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
harbor freight windshield tool. this tool comes with braided wire so it will cut thru the sealant faster. 1 guy can use it to remove glass. if you do it with 2 guys it will work much better. https://www.harborfreight.com/professional-windshield-removal-kit-96339.htmlthe cold knife listed several times requires some skill to use without breakage. if you really want to save the glass call a pro that uses one of these windshield tools. https://www.youtube.com/watch?v=rYpzD-VBq0Iseveral manufacturers make similar tools. the glass co that our shop uses has one. they have removed several hundeds windshields without breakage that are installed with urethane.
perception is 90% of reality
[Re: lostdog]
#2385703
10/11/17 04:29 PM
10/11/17 04:29 PM
lostdog
mississippi
After it was confirmed from you guys that the windshield is set with adhesive, I took a guitar string, slid it under the windshield and sawed it back and forth around the glass. I had it out in about 15 minutes and in ONE piece Thanks, guys!
