Help!!!! I'm an idiot #2383349
10/07/17 11:52 AM
10/07/17 11:52 AM
Ohio
fiddlestix Offline OP
Ohio
I am trying to mount an aluminum master cylinder with the 4 to 2 bolt adapter. When I try to hook up the brake pedal linkage it appears the master cylinder needs to come up about 2". I thought this would be the simple part but can't figure out if I have incorrect parts or having a dumb attack. I assume the latter.
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383350
10/07/17 12:04 PM
10/07/17 12:04 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
is the hole in the fire wall big enough to flip the bracket end for end.what body style is it on,that info might help.
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383352
10/07/17 12:05 PM
10/07/17 12:05 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Hard to beat the factory design.
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383354
10/07/17 12:09 PM
10/07/17 12:09 PM
Ohio
Ohio
This is a 70 Challenger. I think the hole is big enough , but the bolt holes would no line up. All the googled pictures I have looked at look like what I have for manual brakes
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383355
10/07/17 12:14 PM
10/07/17 12:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Did the car have manual breaks initially?
I have mechanical Aptitude.
I can screw up anything.
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383357
10/07/17 12:16 PM
10/07/17 12:16 PM
BDW Offline
BDW  Offline
Hard to tell from pic, should connect to bolt on pedal, not the empty hole.
Re: Help!!!! I'm an idiot [Re: 71birdJ68] #2383360
10/07/17 12:20 PM
10/07/17 12:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I tried to tell him.
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383361
10/07/17 12:27 PM
10/07/17 12:27 PM
Ohio
Ohio
If the master cylinder connects directly to the pedal do you get rid of the linkage completely?
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383380
10/07/17 01:06 PM
10/07/17 01:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Except for the linkage that hooks the pedal direct to the M/C.
Might help if the pictures weren't all sideways.
Might also help if you had a copy of the factory parts book so you could see how it goes together. Probably should have an FSM too.
Don't be the exception.
Re: Help!!!! I'm an idiot [Re: Supercuda] #2383397
10/07/17 01:30 PM
10/07/17 01:30 PM
If manual brakes you would toss all the PB pivot/lever stuff behind the dash & run a pushrod from the pedal straight out to the MC. If the pedal is still a PB unit, the hole may or may not need to be raised or lowered. Make sure the MC choice has the shallow circular recess in the rear piston "thimble" for the neoprene snip to lock into
Re: Help!!!! I'm an idiot [Re: RapidRobert] #2383412
10/07/17 01:48 PM
10/07/17 01:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Stop it, we've had this discussion before. There are exactly 2 pedals available for a 70 E body. One for automatic transmissions and one for manual transmissions. There is ZERO difference for manual or power brake applications.
See clip form factory parts book. The B/J column is E body
Re: Help!!!! I'm an idiot [Re: Supercuda] #2383416
10/07/17 01:55 PM
10/07/17 01:55 PM
Watch your mouth boy, All you gotta say is, actually there is no difference between manual & power brake pedals & I will be corrected.
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383417
10/07/17 01:57 PM
10/07/17 01:57 PM
Ohio
Ohio
Ok , that makes more sense. I was trying to use the linkage from a power drum setup. Next question.... do you use a much shorter pushrod? I bought what I thought was an original manual brake pushrod for a Challenger. It is about 7" long. When connected directly to the brake pedal it makes the pedal position way too high in the car.
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383421
10/07/17 02:07 PM
10/07/17 02:07 PM
I have 2 manual brake pushrods (not handy at the moment) but one is a fair amt shorter than the other. Not sure what they came off of but I would assume A bodies (if that makes a difference) as that is most all I am into tho spares can come from most anything.
Re: Help!!!! I'm an idiot [Re: RapidRobert] #2383423
10/07/17 02:12 PM
10/07/17 02:12 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I believe all bodies (A,B,E) have different length rods
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2383434
10/07/17 02:40 PM
10/07/17 02:40 PM
Ohio
Ohio
Well, it looks like if I buy an adjustable pushrod and forget about the linkage I will be in business. Thanks guys for all your help!!
Re: Help!!!! I'm an idiot [Re: RapidRobert] #2383502
10/07/17 05:54 PM
10/07/17 05:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The reason for the linkage is to reduce the pedal ratio for power brakes so one pedal works on both manual and power.
This is not true of all models, some do have different pedals with different pedal ratios.
Re: Help!!!! I'm an idiot [Re: RapidRobert] #2384769
10/09/17 10:36 PM
10/09/17 10:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You've been corrected more than once.
Hence the suggestion to use the factory parts book and FSM in sorting this crap out.
Re: Help!!!! I'm an idiot [Re: fiddlestix] #2384800
10/09/17 11:21 PM
10/09/17 11:21 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
You should also make a positive stop so the pushrod does not come out of the Mater Cylinder or buy the pushrod from a race supplier that has a trapped push rod . Don't trust the rubber piece.
Real Men shift for themselves
Re: Help!!!! I'm an idiot [Re: 1DGEMAN] #2384814
10/09/17 11:42 PM
10/09/17 11:42 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I know a guy that happened to on the track nervous he was doing about 125 then hit the brakes and no pedal connection at all runaway The only thing that saved him was the Jerico trans that will go into any gear at any speed.
I used an adjustable pushrod from Doctordiff and fabbed my own return spring that keeps the rod in the piston.
Gus beer
64 Plymouth Savoy
Dana 60
