Re: Help!!!! I'm an idiot
[Re: fiddlestix]
#2383380
10/07/17 01:06 PM
10/07/17 01:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Except for the linkage that hooks the pedal direct to the M/C.
Might help if the pictures weren't all sideways.
Might also help if you had a copy of the factory parts book so you could see how it goes together. Probably should have an FSM too.
[Re: Supercuda]
#2383397
10/07/17 01:30 PM
10/07/17 01:30 PM
RapidRobert
If manual brakes you would toss all the PB pivot/lever stuff behind the dash & run a pushrod from the pedal straight out to the MC. If the pedal is still a PB unit, the hole may or may not need to be raised or lowered. Make sure the MC choice has the shallow circular recess in the rear piston "thimble" for the neoprene snip to lock into
[Re: RapidRobert]
#2383412
10/07/17 01:48 PM
10/07/17 01:48 PM
Supercuda
About to go away
About to go away
up yours
If manual brakes you would toss all the PB pivot/lever stuff behind the dash & run a pushrod from the pedal straight out to the MC. If the pedal is still a PB unit, the hole may or may not need to be raised or lowered. Stop it, we've had this discussion before. There are exactly 2 pedals available for a 70 E body. One for automatic transmissions and one for manual transmissions. There is ZERO difference for manual or power brake applications. See clip form factory parts book. The B/J column is E body
[Re: Supercuda]
#2383416
10/07/17 01:55 PM
10/07/17 01:55 PM
RapidRobert
Watch your mouth boy, All you gotta say is, actually there is no difference between manual & power brake pedals & I will be corrected.
[Re: fiddlestix]
#2383421
10/07/17 02:07 PM
10/07/17 02:07 PM
RapidRobert
I have 2 manual brake pushrods (not handy at the moment) but one is a fair amt shorter than the other. Not sure what they came off of but I would assume A bodies (if that makes a difference) as that is most all I am into tho spares can come from most anything.
[Re: RapidRobert]
#2383423
10/07/17 02:12 PM
10/07/17 02:12 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I have 2 manual brake pushrods (not handy at the moment) but one is a fair amt shorter than the other. Not sure what they came off of but I would assume A bodies (if that makes a difference) as that is most all I am into tho spares can come from most anything. I believe all bodies (A,B,E) have different length rods
[Re: RapidRobert]
#2383502
10/07/17 05:54 PM
10/07/17 05:54 PM
Posts: 25,921 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Watch your mouth boy, All you gotta say is, actually there is no difference between manual & power brake pedals & I will be corrected. The reason for the linkage is to reduce the pedal ratio for power brakes so one pedal works on both manual and power. This is not true of all models, some do have different pedals with different pedal ratios.
[Re: RapidRobert]
#2384769
10/09/17 10:36 PM
10/09/17 10:36 PM
Supercuda
About to go away
About to go away
up yours
Watch your mouth boy, All you gotta say is, actually there is no difference between manual & power brake pedals & I will be corrected. You've been corrected more than once. Watch your mouth boy, All you gotta say is, actually there is no difference between manual & power brake pedals & I will be corrected. The reason for the linkage is to reduce the pedal ratio for power brakes so one pedal works on both manual and power. This is not true of all models, some do have different pedals with different pedal ratios. Hence the suggestion to use the factory parts book and FSM in sorting this crap out.
[Re: fiddlestix]
#2384800
10/09/17 11:21 PM
10/09/17 11:21 PM
Posts: 608 TN
1DGEMAN
TN
You should also make a positive stop so the pushrod does not come out of the Mater Cylinder or buy the pushrod from a race supplier that has a trapped push rod . Don't trust the rubber piece.
Real Men shift for themselves
[Re: 1DGEMAN]
#2384814
10/09/17 11:42 PM
10/09/17 11:42 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
You should also make a positive stop so the pushrod does not come out of the Mater Cylinder or buy the pushrod from a race supplier that has a trapped push rod . Don't trust the rubber piece. I know a guy that happened to on the track he was doing about 125 then hit the brakes and no pedal connection at all The only thing that saved him was the Jerico trans that will go into any gear at any speed. I used an adjustable pushrod from Doctordiff and fabbed my own return spring that keeps the rod in the piston. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
