How to avoid oil on small block headers at oil change? #2376869
09/25/17 11:52 PM
09/25/17 11:52 PM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
Is it possible? I have the 90 degree adapter, not that I think it matters although it may make matters worse. Always just hosed the headers down with carb cleaner when I was done since I have cheap painted headers on right now. But I have a shiny pair of Dougs to go on at some point and would like to know how people have avoided the problem.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2376871
09/25/17 11:55 PM
09/25/17 11:55 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
drape a towel or big rag over/around the header tubes.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2376878
09/26/17 12:01 AM
09/26/17 12:01 AM
garbage bag
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2376911
09/26/17 12:49 AM
09/26/17 12:49 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Remote filter adaptor.
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2376924
09/26/17 01:17 AM
09/26/17 01:17 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Bend a piece of metal to catch and drain the oil away from the pipes. Reuse it every time.
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2376985
09/26/17 09:43 AM
09/26/17 09:43 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
Plastic shopping bag over filter as you spin it off
Re: How to avoid oil on small block headers at oil change? [Re: 65rbdodge] #2377069
09/26/17 12:13 PM
09/26/17 12:13 PM
Ding ding ding I (do) believe we have a winna.
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2377152
09/26/17 01:44 PM
09/26/17 01:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
aluminum foil
Don't be the exception.
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2377192
09/26/17 02:56 PM
09/26/17 02:56 PM
WA
tman Online content
tman  Online Content
WA
Plastic shopping bags are not trustworthy. Foil is also good to cover header tubes. I use formafunnel on my Acura cuz it drips all over the lower control arm and crossmember. Also on my BB Cuda.
http://www.formafunnel.com/
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2377273
09/26/17 06:32 PM
09/26/17 06:32 PM
Use a small sharp punch or a nail to put a small hole in the bottom end and catch the oil draining out until it stops dripping up scope twocents
You could also use water(in a spray bottle) to coat the headers before letting oil drip onto them work That only works as long as the pipes are not hot enough to evaporate the water off of them shruggy
Re: How to avoid oil on small block headers at oil change? [Re: Supercuda] #2377692
09/27/17 01:22 PM
09/27/17 01:22 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Originally Posted By Supercuda
aluminum foil
X2 !! Easy to fold around the headers (or exhaust pipe in my application), cheap and easy to get rid of !
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2378282
09/28/17 02:04 PM
09/28/17 02:04 PM
Australia
fullonmopar Offline
fullonmopar  Offline
Australia
All Aussie Chrysler small blocks have a remote filter factory fitted as the steering box is in the way, so not an issue down under.
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2378292
09/28/17 02:15 PM
09/28/17 02:15 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Flip the car over.
Re: How to avoid oil on small block headers at oil change? [Re: MarkZ] #2379383
09/30/17 03:23 PM
09/30/17 03:23 PM
triple up on the grocery plastic bags & use the alum foil.
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2379409
09/30/17 04:27 PM
09/30/17 04:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
How about a remote filter and avoid all the aggravation.
Re: How to avoid oil on small block headers at oil change? [Re: RapidRobert] #2379413
09/30/17 04:30 PM
09/30/17 04:30 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
... don't forget the oil that continues to drain from the adapter as you remove the filter.
Aluminum foil helps
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2379442
09/30/17 06:04 PM
09/30/17 06:04 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Make a trough out of a 2 liter soda bottle cut in half or more,you can leave the cap on to catch the oil or remove the cap & let it drain of if the angle is correct,thats what I use for garden tractor oil filters.
Re: How to avoid oil on small block headers at oil change? [Re: MarkZ] #2379834
10/01/17 11:23 AM
10/01/17 11:23 AM
Columbus, GA
Columbus, GA
Originally Posted By MarkM
Flip the car over.
Nope, then I would have to post "How to avoid getting oil on the underside of my hood at oil change" and no one would be able to help!
In all seriousness the aluminum foil sounds like the route to go as I prefer doing changes with a warm engine. It also along the lines I was already thinking of needing something flat or blanket like, but with raised ends to prevent it just running down the low end and onto the collector.
With wide foil seems like I should be able to cover the tubes and fold up the ends to create a dam at the low end and channel it back down the sides and into the drain pan.
The last post about the soda bottle, I'll totally be using for small engine stuff.
Thanks for the suggestions.
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2379836
10/01/17 11:27 AM
10/01/17 11:27 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They make thick aluminum foil too
Re: How to avoid oil on small block headers at oil change? [Re: Michael Ecks] #2379924
10/01/17 01:50 PM
10/01/17 01:50 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
My smart ass comment aside, I never did get a method down that was 100% fool proof when I still had the 360. My dad ended up using a relocation kit on his 408. If you like changing oil on a warm motor, then this is it. The photo is of the wrong angle, but you can still see it. He mounted the filter on the passenger side up front. Honestly, if you leave the filter where it is at it's only a matter of time until you get oil on your shiny new headers.
