How to avoid oil on small block headers at oil change?
#2376869
09/25/17 11:52 PM
09/25/17 11:52 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Is it possible? I have the 90 degree adapter, not that I think it matters although it may make matters worse. Always just hosed the headers down with carb cleaner when I was done since I have cheap painted headers on right now. But I have a shiny pair of Dougs to go on at some point and would like to know how people have avoided the problem.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: How to avoid oil on small block headers at oil change?
[Re: Michael Ecks]
#2376871
09/25/17 11:55 PM
09/25/17 11:55 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
drape a towel or big rag over/around the header tubes.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: 65rbdodge]
#2377069
09/26/17 12:13 PM
09/26/17 12:13 PM
RapidRobert
Plastic shopping bag over filter as you spin it off Ding ding ding I (do) believe we have a winna.
[Re: MarkZ]
#2379383
09/30/17 03:23 PM
09/30/17 03:23 PM
RapidRobert
triple up on the grocery plastic bags & use the alum foil.
[Re: Michael Ecks]
#2379409
09/30/17 04:27 PM
09/30/17 04:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
How about a remote filter and avoid all the aggravation.
[Re: RapidRobert]
#2379413
09/30/17 04:30 PM
09/30/17 04:30 PM
Posts: 8,131 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Plastic shopping bag over filter as you spin it off Ding ding ding I (do) believe we have a winna. ... don't forget the oil that continues to drain from the adapter as you remove the filter. Aluminum foil helps
[Re: MarkZ]
#2379834
10/01/17 11:23 AM
10/01/17 11:23 AM
Michael Ecks
Columbus, GA
Nope, then I would have to post "How to avoid getting oil on the underside of my hood at oil change" and no one would be able to help! In all seriousness the aluminum foil sounds like the route to go as I prefer doing changes with a warm engine. It also along the lines I was already thinking of needing something flat or blanket like, but with raised ends to prevent it just running down the low end and onto the collector. With wide foil seems like I should be able to cover the tubes and fold up the ends to create a dam at the low end and channel it back down the sides and into the drain pan. The last post about the soda bottle, I'll totally be using for small engine stuff. Thanks for the suggestions.
[Re: Michael Ecks]
#2379836
10/01/17 11:27 AM
10/01/17 11:27 AM
Supercuda
About to go away
About to go away
up yours
They make thick aluminum foil too
