Blower Reference lines #2377317
09/26/17 08:24 PM
09/26/17 08:24 PM
Sudbury, Ontario, Canada
ForcedInductions Offline OP
the issue i have is the reference lines fill up quickly with fuel.
im not sure if it has any affect on the powervalve.
ie damages it, or causes it to not get reading.
i assume (ass out of you and me) that it wont matter it will still see signal.
can anyone confirm or deny these accusations?
Re: Blower Reference lines [Re: ForcedInductions] #2377349
09/26/17 09:36 PM
09/26/17 09:36 PM
confused
Are you asking a question about the blower, carb. or fuel filters?
Re: Blower Reference lines [Re: ForcedInductions] #2377365
09/26/17 09:47 PM
09/26/17 09:47 PM
Az
Crizila Offline
Crizila  Offline
Az
A picture would be worth a 1000 words.
Fastest 300
Re: Blower Reference lines [Re: ForcedInductions] #2377587
09/27/17 10:22 AM
09/27/17 10:22 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I would try to route the line so it drains back to the manifold and no I would not worry about it too much at this point. Do you have your carb setup like this one in my link?
I know you don't want to hear this but, IMO carbs don't work so well on blowers. You should go injection if your gonna use a blower and blow the guys away who are trying to use carbs.
Checkout this link to get familer with what he is asking about.
LINK
Re: Blower Reference lines [Re: ForcedInductions] #2377617
09/27/17 11:16 AM
09/27/17 11:16 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I don't think there should be any fuel in the vac,boost side of the power valve.
Re: Blower Reference lines [Re: Clanton] #2377632
09/27/17 11:39 AM
09/27/17 11:39 AM
Cincinnati, Ohio
Cincinnati, Ohio
Since that line is under boost sometimes it stands to reason that fuel is going find it's way into that line. All you can do is route it so it can drain when the boost goes away. Part of the reason carbs are not the best for blowers.
Re: Blower Reference lines [Re: ForcedInductions] #2377676
09/27/17 12:51 PM
09/27/17 12:51 PM
its a factory referenced carb.
the lines i used are clear so they are fuel milky inside
seems to be running fine
and yes they would see fuel since its manifold pressure/vacc under the carb/blower
so the fuel mixture goes inside.
no picture yet i can take one (never had to take one of a boring reference line before)
Re: Blower Reference lines [Re: ForcedInductions] #2377677
09/27/17 12:52 PM
09/27/17 12:52 PM
next question is diameter of the lines really matter?
Re: Blower Reference lines [Re: ForcedInductions] #2377694
09/27/17 01:23 PM
09/27/17 01:23 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I just have never had fuel in my gauge line for boost,vacuum but that is a 1/8 nylon.I would say you have a leak at some point letting it migrate up the line.
Re: Blower Reference lines [Re: ForcedInductions] #2377699
09/27/17 01:33 PM
09/27/17 01:33 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Your leak may be very small but if you put a hand vacuum pump on the line going to the carb you can test it with the car not running.
Re: Blower Reference lines [Re: ForcedInductions] #2377737
09/27/17 03:04 PM
09/27/17 03:04 PM
i dont have any leaks...
i pull about 15lbs vacuum at idle under the blower.
and hit 12lbs boost. the reference line is under the blower.
where air and fuel are. usually people use black lines.
i just had clear so wanted to make sure.
my line is 1/4 clear hose.
Re: Blower Reference lines [Re: ForcedInductions] #2377766
09/27/17 04:04 PM
09/27/17 04:04 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The 1/4" will be fine!Air moves fast,Just watch for heat related effect like getting too soft or bending and keeping that form.
Re: Blower Reference lines [Re: ForcedInductions] #2377830
09/27/17 05:54 PM
09/27/17 05:54 PM
form seems good.
here is the pix
cant make it all drain back.
its not really a solid more like a foam
Re: Blower Reference lines [Re: ForcedInductions] #2377883
09/27/17 07:05 PM
09/27/17 07:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So those are in the base plate? I just did a pair of 850's for a 588 BB Chevy in a boat and they referenced from the ported hole in the metering blocks w/hard line and no issues w/fuel that I could see and he said they flat out flew............
Re: Blower Reference lines [Re: ForcedInductions] #2377921
09/27/17 08:33 PM
09/27/17 08:33 PM
no they go into the front of each carb just above the mounting flange
so far im not happy with these demons nothing but headaches.
but i had bought them back in 2008.
and didn't use them until a few months ago.
it didnt happen over night it just kept getting milkier and milkier
most of it from flooding during tuning stage. (did more last night)
they seem to be working as the car pulls stupidly hard now.
ill replace them with fresh lines and see if they start building up again.
if it does ill simply go smaller diameter and coloured. (canadian u eh?)
Re: Blower Reference lines [Re: ForcedInductions] #2377953
09/27/17 09:21 PM
09/27/17 09:21 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You can get rid of that Y fitting on the passenger side of the carbs and run 1 line to the tee on the other side.The carbs are sucking oil from the intake that may be from the blower front where you need to relieve the pressure or it can push oil.
Re: Blower Reference lines [Re: ForcedInductions] #2377955
09/27/17 09:24 PM
09/27/17 09:24 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I don't think you have boost referenced pv carbs like that but I would have to see a vac port diagram.
Re: Blower Reference lines [Re: ForcedInductions] #2377957
09/27/17 09:28 PM
09/27/17 09:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I can fix the carbs for ya and you can see LOTS of vids and pics on FB under Dominic Thumper and have also done several for peeps on here........... beer
Re: Blower Reference lines [Re: ForcedInductions] #2377960
09/27/17 09:31 PM
09/27/17 09:31 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
if that tubing goes to the power valve you should not be able to blow in it freely
Re: Blower Reference lines [Re: ForcedInductions] #2377962
09/27/17 09:38 PM
09/27/17 09:38 PM
these are the carbs
http://www.speedwaymotors.com/Barry-Grant-Demon-Inline-Twin-Blower-Supercharger-Carbs,5849.html
bought them before barry grant went bankrupt
they are the 725cfm edition blower reference carbs
part number 91012066
there is no T on the other side.
