AAR Antenna Mounting #2375942
09/24/17 03:18 PM
09/24/17 03:18 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
I'd like to ask a question based on the "never-say-never" MOPAR builds and that the Engineering drawing doesn't really address this aspect.
So I went to mount the antenna (original hardware) and notice the base can be mounted only two ways, with very minor clocking adjustment once installed.
A friend of mine has pic's of his prior to teardown the way opposite I believe to be as intended. Unfortunately my pics prior to teardown had the antenna removed.
So I'm hoping a few of you have pics of your AAR's prior to teardown or survivor pics to ref.
So I loosely placed the mounts in and placed a screw driver in the hole to show the positioning.
Option 1 - Basically straight up and down, it appears this position will clear the ducktail when the trunk is opened and should pose no other issues.
Option 2 - By turning the hardware 180 degrees out the position changes to leaning AFT and Outboard. This too clears the ducktail when the trunk is open by leaning just Outboard of the spoiler, due to the leaned back angle this would be needed.
(pics to follow)
Re: AAR Antenna Mounting [Re: AAR#2] #2375943
09/24/17 03:20 PM
09/24/17 03:20 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Option 1
Re: AAR Antenna Mounting [Re: AAR#2] #2375945
09/24/17 03:22 PM
09/24/17 03:22 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Option 2
Re: AAR Antenna Mounting [Re: AAR#2] #2375948
09/24/17 03:24 PM
09/24/17 03:24 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
OMG, so annoying, why do the images turn on their side and how can I correct it . . .??
They open correctly when not in this thread.
Re: AAR Antenna Mounting [Re: AAR#2] #2375955
09/24/17 03:38 PM
09/24/17 03:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Straight up.
(the antenna, I can see sideways just fine, so I am not picking on your photos self-orientation)
Re: AAR Antenna Mounting [Re: AAR#2] #2375957
09/24/17 03:44 PM
09/24/17 03:44 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thanks Barry, of course I have little doubt a few got installed incorrectly at the factory, and in his case if he chooses to prove it with a photo, that would be acceptable in my opinion.
Re: AAR Antenna Mounting [Re: AAR#2] #2375969
09/24/17 04:13 PM
09/24/17 04:13 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My original paint car has the antenna straight up. It's never been off.
Re: AAR Antenna Mounting [Re: AAR#2] #2375978
09/24/17 04:28 PM
09/24/17 04:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Antenna masts were not installed at the factory. For an AAR the mast would have been shipped in the trunk with the trim rings & side exhaust pipes for dealership installation.
So it would be very unlikely to find a 'factory' photo of an AAR with the mast installed. wink
Re: AAR Antenna Mounting [Re: AAR#2] #2375994
09/24/17 05:27 PM
09/24/17 05:27 PM
NJ
JH23 Offline
JH23  Offline
NJ
Were the antennas shipped with a template for where to drill the hole or were they drilled or stamped out with the hole?
Re: AAR Antenna Mounting [Re: AAR#2] #2375997
09/24/17 05:35 PM
09/24/17 05:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The holes were pre-punched (for cars optioned with a radio).
The bases were installed at the factory.
But the masts were shipped in the trunk.
Re: AAR Antenna Mounting [Re: Alaskan_TA] #2376102
09/24/17 10:31 PM
09/24/17 10:31 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Perhaps semantics but the base installation is what determines the antenna mast angle, so it would still be a factory error as all the dealer did was thread in the mast.
Thanks guys
Re: AAR Antenna Mounting [Re: AAR#2] #2376142
09/24/17 11:21 PM
09/24/17 11:21 PM
North Central USA (MN-WI area)
MuscleMopars Offline
Mine
Thanks,
Eric
email eric@musclemopars.com
715-426-HEMI (Shop)
612-669-CARS (Cell and Texts)
Go to my Moparts "Profile" to see my web site
Re: AAR Antenna Mounting [Re: MuscleMopars] #2376161
09/25/17 12:06 AM
09/25/17 12:06 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Mine is straight up on my car.
The only Carbs I care about are under the hood!
Re: AAR Antenna Mounting [Re: AAR#2] #2376618
09/25/17 05:55 PM
09/25/17 05:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Thanks guys
Think about it this way;
The antenna base has a provision for the antenna cable from the radio to attach to.
So, logic would dictate that that the installer would point that connection towards the front of the car where the radio is to avoid a sharp, unnecessary bend in the cable.
Re: AAR Antenna Mounting [Re: Azzkikrcuda] #2376702
09/25/17 08:32 PM
09/25/17 08:32 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: AAR Antenna Mounting [Re: AAR#2] #2376912
09/26/17 12:49 AM
09/26/17 12:49 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's mine and it's straight up...... wink
Re: AAR Antenna Mounting [Re: AAR#2] #2383620
10/07/17 10:46 PM
10/07/17 10:46 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Do AARs and T/As come with a rectangular reinforcement plate under the quarter panel? I've seen a couple for sale on eBay and don't see it on the engineering drawing. I'm moving the antenna on my Challenger to the quarter panel (I like the look) and am wondering if I need to get one of those brackets?
When you work on Spaceships for a living, how bad can a workday be?
Re: AAR Antenna Mounting [Re: AAR#2] #2383636
10/07/17 11:47 PM
10/07/17 11:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have a spare one here somewhere.
