Re: AAR Antenna Mounting
[Re: AAR#2]
#2375994
09/24/17 05:27 PM
09/24/17 05:27 PM
Posts: 190 NJ
JH23
NJ
Were the antennas shipped with a template for where to drill the hole or were they drilled or stamped out with the hole?
[Re: Alaskan_TA]
#2376102
09/24/17 10:31 PM
09/24/17 10:31 PM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
The holes were pre-punched (for cars optioned with a radio).
The bases were installed at the factory.
But the masts were shipped in the trunk. Perhaps semantics but the base installation is what determines the antenna mast angle, so it would still be a factory error as all the dealer did was thread in the mast. Thanks guys
[Re: AAR#2]
#2376618
09/25/17 05:55 PM
09/25/17 05:55 PM
Posts: 29,651 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
But the masts were shipped in the trunk. Perhaps semantics but the base installation is what determines the antenna mast angle, so it would still be a factory error as all the dealer did was thread in the mast. Thanks guys Think about it this way; The antenna base has a provision for the antenna cable from the radio to attach to. So, logic would dictate that that the installer would point that connection towards the front of the car where the radio is to avoid a sharp, unnecessary bend in the cable.
[Re: AAR#2]
#2383620
10/07/17 10:46 PM
10/07/17 10:46 PM
Posts: 406 California City, CA
dart440
California City, CA
Do AARs and T/As come with a rectangular reinforcement plate under the quarter panel? I've seen a couple for sale on eBay and don't see it on the engineering drawing. I'm moving the antenna on my Challenger to the quarter panel (I like the look) and am wondering if I need to get one of those brackets?
When you work on Spaceships for a living, how bad can a workday be?
