Re: I need a fender tag for a 1968 Roadrunner Help
[Re: mad car disease]
#237586
02/27/09 12:04 PM
02/27/09 12:04 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Apparently Chryler Historical Society has the IBM punch cards for some '67 and prior vehicles. I believe the story is that the '68 and up stuff was lost in a fire.
Unless you can dig out a broadcast sheet, you're SOL as far as getting an accurate repop tag made.
Cheers, Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#237587
02/27/09 12:18 PM
02/27/09 12:18 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Cheers, Dave
#237589
02/28/09 12:44 AM
02/28/09 12:44 AM
Posts: 2,601 Great White North
Furyman
Great White North
I think if the car is fairly original -ie unrestored a Fairly accurate repop could be made. There is basically no guesswork except for order #. A good eye will be able to spot a repop fender tag pretty easily....there are always one or two cars every given week on e-gag with repop tags.
"Long Live Mopars"
#237590
02/28/09 12:54 AM
02/28/09 12:54 AM
340dart4spd
Parts Problem
Parts Problem
I am missing the fender tag on a 68 roadrunner. isn't there some kinda punch card data for 68 and back or is that 67 and back?
thanks
Where else EBAY HAS EM......LOL guy out of Canada is selling tags there... go figure....
[Re: Furyman]
#237592
02/28/09 02:11 AM
02/28/09 02:11 AM
340dart4spd
Parts Problem
Parts Problem
sylvain is selling original tags not repops.
Who said he was?
[Re: Butterscotch71]
#237596
02/28/09 11:11 PM
02/28/09 11:11 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
Yep. The only place the vin is on the car is the tag on the dash.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#237597
03/01/09 12:22 AM
03/01/09 12:22 AM
Posts: 862 Doo-Dah, KS
440fied
Doo-Dah, KS
and on the block and transmission for some cars built after Jan. 1, 1968
[Re: RoadRunner]
#237599
03/01/09 11:50 PM
03/01/09 11:50 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
You would also have to know what codes were used at what plants during what time of year to make an accurate tag. Not all codes were used at all plants all model year. Codes came and went.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#237600
03/02/09 09:18 PM
03/02/09 09:18 PM
Furyman
Great White North
All you need is a big enough database....couple thousand tags per year will cover it pretty much.I had a major brain fart on the so # .Build dates are pretty straight forward although every once in a while a real wild card will get thrown in.I see nothing wrong with a repop tag especially if there is other documentation....IBM card,broadcast..rotted original tag etc etc.Problem comes in with misrepresentation...colour change.....trans change options added etc.Like I said before the one good thing is repop tags can be spotted. Order #'s for post 68 cars can be a problem but again with a big enough database I think that could be figured out.
"Long Live Mopars"
