I need a fender tag for a 1968 Roadrunner Help #237584
02/26/09 11:31 PM
02/26/09 11:31 PM
vancouver wa
mad car disease Offline OP
vancouver wa
I am missing the fender tag on a 68 roadrunner. isn't there some kinda punch card data for 68 and back or is that 67 and back?
thanks
Re: I need a fender tag for a 1968 Roadrunner Help [Re: mad car disease] #237585
02/26/09 11:49 PM
02/26/09 11:49 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
with out an original to copy
the best you can do is a guess
good luck
Re: I need a fender tag for a 1968 Roadrunner Help [Re: mad car disease] #237586
02/27/09 12:04 PM
02/27/09 12:04 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Apparently Chryler Historical Society has the IBM punch cards for some '67 and prior vehicles. I believe the story is that the '68 and up stuff was lost in a fire.
Unless you can dig out a broadcast sheet, you're SOL as far as getting an accurate repop tag made.
Cheers,
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: I need a fender tag for a 1968 Roadrunner Help [Re: DPelletier] #237587
02/27/09 12:18 PM
02/27/09 12:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Cheers,
Re: I need a fender tag for a 1968 Roadrunner Help [Re: mad car disease] #237588
02/27/09 10:07 PM
02/27/09 10:07 PM
vancouver wa
vancouver wa
Thanks guys. I was afraid it was 67 and back. Too bad that they didn't have those cards 68 and up any more. It sure would have made things allot easier.
Re: I need a fender tag for a 1968 Roadrunner Help [Re: mad car disease] #237589
02/28/09 12:44 AM
02/28/09 12:44 AM
Great White North
Furyman Offline
Furyman  Offline
Great White North
I think if the car is fairly original -ie unrestored a Fairly accurate repop could be made.
There is basically no guesswork except for order #.
A good eye will be able to spot a repop fender tag pretty easily....there are always one or two cars every given week on e-gag with repop tags.
"Long Live Mopars"
Re: I need a fender tag for a 1968 Roadrunner Help [Re: mad car disease] #237590
02/28/09 12:54 AM
02/28/09 12:54 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
thanks
Where else EBAY HAS EM......LOL guy out of Canada is selling tags there... go figure....
Re: I need a fender tag for a 1968 Roadrunner Help [Re: 340dart4spd ] #237591
02/28/09 02:02 AM
02/28/09 02:02 AM
Great White North
Furyman Offline
Furyman  Offline
Great White North
sylvain is selling original tags not repops.
"Long Live Mopars"
Re: I need a fender tag for a 1968 Roadrunner Help [Re: Furyman] #237592
02/28/09 02:11 AM
02/28/09 02:11 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Who said he was?
Re: I need a fender tag for a 1968 Roadrunner Help [Re: Furyman] #237593
02/28/09 07:36 PM
02/28/09 07:36 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
The order number is on the radiator support. You could get it easily.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: I need a fender tag for a 1968 Roadrunner Help [Re: Prodart440] #237594
02/28/09 10:30 PM
02/28/09 10:30 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
68s had the VON (vehicle order number) stamped on the rad support???? I though only partial VINs were stamped on the body.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: I need a fender tag for a 1968 Roadrunner Help [Re: Butterscotch71] #237595
02/28/09 11:03 PM
02/28/09 11:03 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Yes, 68s have the sales order number on the radiator support and the driver's side trunk lip under the weatherstipping.
Re: I need a fender tag for a 1968 Roadrunner Help [Re: Butterscotch71] #237596
02/28/09 11:11 PM
02/28/09 11:11 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Yep. The only place the vin is on the car is the tag on the dash.
Aaron
68 Coronet 440
Re: I need a fender tag for a 1968 Roadrunner Help [Re: Prodart440] #237597
03/01/09 12:22 AM
03/01/09 12:22 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
and on the block and transmission for some cars built after Jan. 1, 1968
Re: I need a fender tag for a 1968 Roadrunner Help [Re: Furyman] #237598
03/01/09 11:37 PM
03/01/09 11:37 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Two of the harder things to figure out on the 68 tag without the build sheet are the order date, tires and wheel combo (unless the originals are still on the car, which isn't likely after 40 years, well, maybe the wheels). The SO number is the number stamped on the radiator support and trunk lid. The VIN does not show up.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: I need a fender tag for a 1968 Roadrunner Help [Re: RoadRunner] #237599
03/01/09 11:50 PM
03/01/09 11:50 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
You would also have to know what codes were used at what plants during what time of year to make an accurate tag.
Not all codes were used at all plants all model year. Codes came and went.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: I need a fender tag for a 1968 Roadrunner Help [Re: 69CoronetRT] #237600
03/02/09 09:18 PM
03/02/09 09:18 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
All you need is a big enough database....couple thousand tags per year will cover it pretty much.I had a major brain fart on the so # .Build dates are pretty straight forward although every once in a while a real wild card will get thrown in.I see nothing wrong with a repop tag especially if there is other documentation....IBM card,broadcast..rotted original tag etc etc.Problem comes in with misrepresentation...colour change.....trans change options added etc.Like I said before the one good thing is repop tags can be spotted.
Order #'s for post 68 cars can be a problem but again with a big enough database I think that could be figured out.
"Long Live Mopars"
Re: I need a fender tag for a 1968 Roadrunner Help [Re: Furyman] #237601
03/03/09 01:39 PM
03/03/09 01:39 PM
DPelletier Offline
DPelletier  Offline
I see nothing wrong with a repop tag ONLY if there is other documentation....IBM card,broadcast..rotted original tag etc etc.Problem comes in with misrepresentation...colour change.....trans change options added etc.
....fixed it for you!
