Dumb Question I Guess #2375262
09/22/17 11:49 PM
09/22/17 11:49 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
Putting new wires and cap on my new 440.
Check me..... Firing order 18436572, CW distributor rotation, drivers side odd cylinders, #1 closest to radiator? Looking down on the distributor with the cap notch as a reference, where does #1 wire go?
Thank you in advance
Re: Dumb Question I Guess [Re: 70VERT] #2375269
09/23/17 12:07 AM
09/23/17 12:07 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
You will have to get the engine on top dead center on the compression stroke for cylinder #1 to know. The rotor will be pointing to the cap location for the #1 cylinder wire.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Dumb Question I Guess [Re: 70VERT] #2375270
09/23/17 12:07 AM
09/23/17 12:07 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
The ones I've had in the past, #1 was 6 o'clock when standing at passenger side fender looking down at distributor cap.
Best way would be to bring #1 to TDC on compression stroke and remove cap to verify location.
Are you familiar with that procedure? If not holler out & we'll walk you through.
Re: Dumb Question I Guess [Re: 70VERT] #2375271
09/23/17 12:08 AM
09/23/17 12:08 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
rotation is ccw by the way and #1 rotor point area is kinda towards fuel pump area. About 4 oclock as you're standing on right side of engine looking at it.
Re: Dumb Question I Guess [Re: 70VERT] #2375275
09/23/17 12:12 AM
09/23/17 12:12 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
distributor rotation and cylinder numbers.jpgengine sketch with distributer  rotation 2.jpgengine sketch with distributer rotation 1.jpg
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Dumb Question I Guess [Re: buildanother] #2375308
09/23/17 01:37 AM
09/23/17 01:37 AM
from pass side fender: #1 plug wire at 5 o'clock & this is just below the front dist cap spring retainer strap. vac can straight across toward the drivers side at 12 o'clock. this lets the wires nestle the neatest & maintains the OE order. I would reclock the intergear to achieve that. Yes CCW
Re: Dumb Question I Guess [Re: RapidRobert] #2375316
09/23/17 01:51 AM
09/23/17 01:51 AM
iagree up
That's the way I do all of mine except on the vacuum pod, it may end up to the front or rear a liitle more, depending on the cam and oil pump gear shruggy scope
Re: Dumb Question I Guess [Re: 70VERT] #2375317
09/23/17 01:52 AM
09/23/17 01:52 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
There are no dumb questions man. That's why folks come on here. Aren't you glad you asked?
Re: Dumb Question I Guess [Re: 70VERT] #2375348
09/23/17 05:15 AM
09/23/17 05:15 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Where #1 will be will also depend on how the distributor is installed. If it was just dropped in randomly, #1 can be anywhere.
Re: Dumb Question I Guess [Re: slantzilla] #2375379
09/23/17 10:51 AM
09/23/17 10:51 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It's not a chevy, either it's right, or it's a 180 out.
Re: Dumb Question I Guess [Re: 70VERT] #2375384
09/23/17 11:00 AM
09/23/17 11:00 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you want the distributor and wires to be in the OE positions, then the drive must be installed in the correct orientation. The drive's slot needs to be parallel to the crank when #1 is at TDC on the compression stroke.
Master, again and still
Re: Dumb Question I Guess [Re: DaveRS23] #2375411
09/23/17 11:58 AM
09/23/17 11:58 AM
There are no dumb questions (only rude replies on occaision & that too is getting way lesser), now way back a guy asked on how to deal with his dogs' flatulence (in the general section iirc/& I would assume) & I knew right then that I need to stay in the Q&A section & not stray (I might like it).
Re: Dumb Question I Guess [Re: 70VERT] #2375626
09/23/17 07:48 PM
09/23/17 07:48 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Be glad you don't live with me. 3 dogs....
Angry white pureblood male
Re: Dumb Question I Guess [Re: 70VERT] #2375689
09/23/17 09:57 PM
09/23/17 09:57 PM
cbusters Offline
cbusters  Offline
There was a racer tip at one time that suggested that a Ford rotor was 180 degrees out from a Mopar and would fit. If the distributor was dropped in at the track pointing the wrong direction and wouldn't fire they would just pop the cap and replace the rotor and it would fire. Anyone else remember something like that?
Re: Dumb Question I Guess [Re: cbusters] #2375706
09/23/17 10:25 PM
09/23/17 10:25 PM
that would be a Hell of a trick.
Re: Dumb Question I Guess [Re: 70VERT] #2375730
09/23/17 11:03 PM
09/23/17 11:03 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have always set mine up with #1 position closest to #1 cyl.
Back when I first started out playing fast cars, I went to the track with my bargain 440 race motor in my 63 Ply, took 3 meetings to figure out that it had a small block twin point dissy (reverse rotation) and just to make sure we learners failed the timing tape on the balancer was on backwards !!!!! Dumb and Dumber Racing smile
1963 Plymouth Max Wedge
1971 Barracuda
Re: Dumb Question I Guess [Re: cbusters] #2376217
09/25/17 02:03 AM
09/25/17 02:03 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Yes. Saw it done a few times.
Re: Dumb Question I Guess [Re: Dave Hall] #2376672
09/25/17 07:28 PM
09/25/17 07:28 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
iagree There's no such thing as a dumb question.
Re: Dumb Question I Guess [Re: slantzilla] #2376678
09/25/17 07:35 PM
09/25/17 07:35 PM
We need a (furd) part number
