Re: Dumb Question I Guess
[Re: 70VERT]
#2375269
09/23/17 12:07 AM
09/23/17 12:07 AM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
You will have to get the engine on top dead center on the compression stroke for cylinder #1 to know. The rotor will be pointing to the cap location for the #1 cylinder wire.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: buildanother]
#2375308
09/23/17 01:37 AM
09/23/17 01:37 AM
RapidRobert
from pass side fender: #1 plug wire at 5 o'clock & this is just below the front dist cap spring retainer strap. vac can straight across toward the drivers side at 12 o'clock. this lets the wires nestle the neatest & maintains the OE order. I would reclock the intergear to achieve that. Yes CCW
[Re: 70VERT]
#2375317
09/23/17 01:52 AM
09/23/17 01:52 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
There are no dumb questions man. That's why folks come on here. Aren't you glad you asked?
[Re: 70VERT]
#2375348
09/23/17 05:15 AM
09/23/17 05:15 AM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
Where #1 will be will also depend on how the distributor is installed. If it was just dropped in randomly, #1 can be anywhere.
[Re: 70VERT]
#2375384
09/23/17 11:00 AM
09/23/17 11:00 AM
Posts: 12,160 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you want the distributor and wires to be in the OE positions, then the drive must be installed in the correct orientation. The drive's slot needs to be parallel to the crank when #1 is at TDC on the compression stroke.
Master, again and still
[Re: DaveRS23]
#2375411
09/23/17 11:58 AM
09/23/17 11:58 AM
RapidRobert
There are no dumb questions (only rude replies on occaision & that too is getting way lesser), now way back a guy asked on how to deal with his dogs' flatulence (in the general section iirc/& I would assume) & I knew right then that I need to stay in the Q&A section & not stray (I might like it).
[Re: 70VERT]
#2375626
09/23/17 07:48 PM
09/23/17 07:48 PM
Posts: 5,886 ohio
ruderunner
ohio
Be glad you don't live with me. 3 dogs....
Angry white pureblood male
[Re: cbusters]
#2375706
09/23/17 10:25 PM
09/23/17 10:25 PM
RapidRobert
that would be a Hell of a trick.
[Re: 70VERT]
#2375730
09/23/17 11:03 PM
09/23/17 11:03 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have always set mine up with #1 position closest to #1 cyl. Back when I first started out playing fast cars, I went to the track with my bargain 440 race motor in my 63 Ply, took 3 meetings to figure out that it had a small block twin point dissy (reverse rotation) and just to make sure we learners failed the timing tape on the balancer was on backwards !!!!! Dumb and Dumber Racing
1963 Plymouth Max Wedge 1971 Barracuda
[Re: cbusters]
#2376217
09/25/17 02:03 AM
09/25/17 02:03 AM
slantzilla
Park Forest, IL
There was a racer tip at one time that suggested that a Ford rotor was 180 degrees out from a Mopar and would fit. If the distributor was dropped in at the track pointing the wrong direction and wouldn't fire they would just pop the cap and replace the rotor and it would fire. Anyone else remember something like that? Yes. Saw it done a few times.
