'70 Challenger decklid and 1/4 panel trim hardware #2374290
09/21/17 12:52 AM
09/21/17 12:52 AM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
So I bought a decklid and 1/4 panel trim hardware kit and am not sure how and the order in which the metal bolt thigies and plastic clips go. This kit has 8 bolt things and 5 plastic clips. There are 3 holes for each 1/4 trim and 7 for the deck lid so that is good that they equal the same number. Also which way do the "antenae" on the bolts go? If anyone has a picture of the hardware installed on the trim it would be great.
Re: '70 Challenger decklid and 1/4 panel trim hardware [Re: challenger70] #2374357
09/21/17 08:01 AM
09/21/17 08:01 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
The metal studs go on the quarter end trim, the plastic retainers on the trunk lid (chrome snaps onto it),.....and I believe.... there are studs on the very end of the trunk lid chrome, one on each end.
jess
Yeah, it's hopped up to over 160...
Re: '70 Challenger decklid and 1/4 panel trim hardware [Re: jt4406] #2374388
09/21/17 10:24 AM
09/21/17 10:24 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
jess
Yes, that is correct. Or at least how mine are done.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: '70 Challenger decklid and 1/4 panel trim hardware [Re: challenger70] #2374419
09/21/17 11:29 AM
09/21/17 11:29 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Plastic go in deck lid wholes, set them in place then push in the center to expand them so they stay in place... trim snaps into place over them. Metal clip, can only go 2 ways... put them in and turn the way the nut would spin and you'll figure out the correct way.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: '70 Challenger decklid and 1/4 panel trim hardware [Re: Silver70] #2374431
09/21/17 11:44 AM
09/21/17 11:44 AM
Berwyn, IL
Berwyn, IL
Thanks guys up I am a little leery of snapping the trim over these plastic clips nervous but I will give it a go. So 1/4 panel trim gets all 3 metal studs a piece and the trunk trim gets the studs on the ends and the 5 middle spots get the plastic retainer. The plastic retainers get installed onto the decklid itself. Seems like it will be tricky to snap the decklid trim on and get the end studs into their holes. I guess you wanna start with the top of the trim and then snap it over the bottom of the plastic retainers?
Would there be any reason you couldn't use all metal studs and bypass the plastic retainers all together? I imagine they serve some purpose besides being cheaper than the metal studs.
Re: '70 Challenger decklid and 1/4 panel trim hardware [Re: challenger70] #2374440
09/21/17 12:04 PM
09/21/17 12:04 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
I believe it is a clearance issue, stud tip to trunk seal? (not an issue at the ends)
Yes, trim to top, snap over bottom.
Jess
Re: '70 Challenger decklid and 1/4 panel trim hardware [Re: challenger70] #2374483
09/21/17 01:22 PM
09/21/17 01:22 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Won't those studs clip into the trim piece first? Then you can slide them to line up the holes?
Re: '70 Challenger decklid and 1/4 panel trim hardware [Re: Dave Hall] #2374520
09/21/17 02:08 PM
09/21/17 02:08 PM
Berwyn, IL
Berwyn, IL
Yes, but if I have to snap the trim strip onto the plastic retainers, not sure if they will go happily into their holes at the same time.
Re: '70 Challenger decklid and 1/4 panel trim hardware [Re: challenger70] #2374543
09/21/17 02:37 PM
09/21/17 02:37 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
They will as they are long enough to start the hole before the trim snaps to the plastic. I did my '72 but it's been so long ago that I couldn't remember.
