Re: '70 Challenger decklid and 1/4 panel trim hardware
[Re: challenger70]
#2374357
09/21/17 08:01 AM
09/21/17 08:01 AM
Posts: 1,567 Ky
jt4406
Ky
The metal studs go on the quarter end trim, the plastic retainers on the trunk lid (chrome snaps onto it),.....and I believe.... there are studs on the very end of the trunk lid chrome, one on each end. jess
Yeah, it's hopped up to over 160...
[Re: jt4406]
#2374388
09/21/17 10:24 AM
09/21/17 10:24 AM
Posts: 4,570 Motor City
6PKRTSE
Motor City
The metal studs go on the quarter end trim, the plastic retainers on the trunk lid (chrome snaps onto it),.....and I believe.... there are studs on the very end of the trunk lid chrome, one on each end. jess Yes, that is correct. Or at least how mine are done.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: challenger70]
#2374419
09/21/17 11:29 AM
09/21/17 11:29 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Plastic go in deck lid wholes, set them in place then push in the center to expand them so they stay in place... trim snaps into place over them. Metal clip, can only go 2 ways... put them in and turn the way the nut would spin and you'll figure out the correct way.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2374431
09/21/17 11:44 AM
09/21/17 11:44 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Thanks guys I am a little leery of snapping the trim over these plastic clips but I will give it a go. So 1/4 panel trim gets all 3 metal studs a piece and the trunk trim gets the studs on the ends and the 5 middle spots get the plastic retainer. The plastic retainers get installed onto the decklid itself. Seems like it will be tricky to snap the decklid trim on and get the end studs into their holes. I guess you wanna start with the top of the trim and then snap it over the bottom of the plastic retainers? Would there be any reason you couldn't use all metal studs and bypass the plastic retainers all together? I imagine they serve some purpose besides being cheaper than the metal studs.
[Re: challenger70]
#2374440
09/21/17 12:04 PM
09/21/17 12:04 PM
Posts: 1,567 Ky
jt4406
Ky
Would there be any reason you couldn't use all metal studs and bypass the plastic retainers all together? I imagine they serve some purpose I believe it is a clearance issue, stud tip to trunk seal? (not an issue at the ends) Yes, trim to top, snap over bottom. Jess
