Who makes the best 7290 joint now? #2371723
09/16/17 02:56 PM
09/16/17 02:56 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I have always used the Spicer forged joints in the past and not had any trouble. I understand that they are no longer forged, but cast. Is that true?
So, whose 7290 do you use? Something that will hold a 1.5 60' with 3,800lbs.
I know I should go to 1350s. And might, just not right now.
Thanks!
Master, again and still
Re: Who makes the best 7290 joint now? [Re: DaveRS23] #2371796
09/16/17 05:54 PM
09/16/17 05:54 PM
I've heard good on Spicer and Neapco. I would use a solid (no zerk) one.
Re: Who makes the best 7290 joint now? [Re: DaveRS23] #2371824
09/16/17 07:13 PM
09/16/17 07:13 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
http://spicerparts.com/parts/driveshaft/automotive-performance/spicer-life-series-u-joints
Spicer says that their joints are "cold forged". And they still offer a non-greasable version.
5-811X runs about $24 or so.
And it seems that Lakewood offers an expensive 7290.
So, I think I will order a 5-811X Spicer.
Re: Who makes the best 7290 joint now? [Re: DaveRS23] #2371859
09/16/17 08:41 PM
09/16/17 08:41 PM
If you could confirm that your choice is made in the USA that would be a smart move. On a side note, after installation confirm that it moves freely in both planes on the front yoke & the one plane on the rear ujoint, smoothly & no binding & if not then whack the "ears" till it does.
Re: Who makes the best 7290 joint now? [Re: DaveRS23] #2371902
09/16/17 10:26 PM
09/16/17 10:26 PM
Cab_Burge Online work
Cab_Burge  Online Work
I like and buy the Neapco H.D joints for all my cars that will get beat on hammer
Re: Who makes the best 7290 joint now? [Re: DaveRS23] #2371935
09/16/17 11:17 PM
09/16/17 11:17 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Spicer non-greasable "snap-tite" U-joints are the best.
They require a little more attention during installation, however.
Re: Who makes the best 7290 joint now? [Re: DaveRS23] #2371961
09/16/17 11:51 PM
09/16/17 11:51 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
2nd on the spicer 5-811x, neapco are good too. The last time I checked the spicer had more and smaller needles, which left the cross .010 bigger in diameter than the other brands. Mic the cross bearing surface diameter, bigger is better.
Re: Who makes the best 7290 joint now? [Re: DaveRS23] #2372134
09/17/17 12:02 PM
09/17/17 12:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run Brute Force joints.Advanced used to carry them.I dont know if they still do but tey are usually on Ebay.Solid and they are tough.Belieb neapco made them.Rocky
Chrysler Firepower
Re: Who makes the best 7290 joint now? [Re: DaveRS23] #2372501
09/18/17 01:38 AM
09/18/17 01:38 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I used to burn through a Neapco in about a year but the spicers would last for years...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
