Who makes the best 7290 joint now?
#2371723
09/16/17 02:56 PM
09/16/17 02:56 PM
Posts: 12,233 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have always used the Spicer forged joints in the past and not had any trouble. I understand that they are no longer forged, but cast. Is that true?
So, whose 7290 do you use? Something that will hold a 1.5 60' with 3,800lbs.
I know I should go to 1350s. And might, just not right now.
Thanks!
Master, again and still
Re: Who makes the best 7290 joint now?
[Re: DaveRS23]
#2371796
09/16/17 05:54 PM
09/16/17 05:54 PM
RapidRobert
I've heard good on Spicer and Neapco. I would use a solid (no zerk) one.
[Re: DaveRS23]
#2371859
09/16/17 08:41 PM
09/16/17 08:41 PM
RapidRobert
If you could confirm that your choice is made in the USA that would be a smart move. On a side note, after installation confirm that it moves freely in both planes on the front yoke & the one plane on the rear ujoint, smoothly & no binding & if not then whack the "ears" till it does.
[Re: DaveRS23]
#2372134
09/17/17 12:02 PM
09/17/17 12:02 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I run Brute Force joints.Advanced used to carry them.I dont know if they still do but tey are usually on Ebay.Solid and they are tough.Belieb neapco made them.Rocky
Chrysler Firepower
[Re: DaveRS23]
#2372501
09/18/17 01:38 AM
09/18/17 01:38 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I used to burn through a Neapco in about a year but the spicers would last for years...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
