Re: Big Power, Small Tire [Re: Wookie316] #2368878
09/11/17 04:00 PM
09/11/17 04:00 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
Like others have said - go with the PBR and don't look back. I also have a small radial tire class car I run and use the 28 x 10.5 wherever its allowed in the rules. I've been a 1.19 60' @ 3200 on a leaf spring with that tire on a not that great track. That AND I have to pull power to keep the front end down. That tire is fantastic!
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: Big Power, Small Tire [Re: Wookie316] #2368886
09/11/17 04:19 PM
09/11/17 04:19 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Aren't the DOT tires quite a bit heavier than drag slicks?
Re: Big Power, Small Tire [Re: Runnoft] #2369263
09/12/17 08:46 AM
09/12/17 08:46 AM
Mo.
racerx Offline
racerx  Offline
Mo.
1.19 on springs is impressive, what kind of car is this?
Re: Big Power, Small Tire [Re: racerx] #2369308
09/12/17 11:41 AM
09/12/17 11:41 AM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
I hesitated to mention the car since its brand X. A 1966 Chevy II with a procharged smallblock.
Re: Big Power, Small Tire [Re: fast68plymouth] #2369609
09/12/17 07:47 PM
09/12/17 07:47 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
the DOT (SS) are heavier than the PBR which is heavier than a rag slick . The Hoosier DOT 275 radial is noticeably lighter than the PBR but does not have the life , and are a [censored] to fit hate to fit 1 on a 10"rim . BUT a lot run a tube with rag slicks so put some weight back .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Big Power, Small Tire [Re: Wookie316] #2370737
09/14/17 02:27 PM
09/14/17 02:27 PM
Alberta
Wookie316 Offline OP
Alberta
Would a combo of the M/T having 2" more roll out and having to run less PSI account for the lower ET & MPH?
The 60 foots were very close. 1.41 Hoosier & 1.42 M/T.
Hope to try Castrol this Sunday.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Big Power, Small Tire [Re: Wookie316] #2370775
09/14/17 03:29 PM
09/14/17 03:29 PM
So. Burlington, Vt.
So. Burlington, Vt.
Could those things have a negative impact on the cars performance?
Sure.
Only one way to know for sure.
Any significant difference in weight between the two?
Re: Big Power, Small Tire [Re: Wookie316] #2370791
09/14/17 04:10 PM
09/14/17 04:10 PM
Alberta
Alberta
31 Lbs on the M/T. The Hoosier does not list the weight on their site. But I see Jegs says 26 Lbs. So 5 Lbs probably does not help.
Re: Big Power, Small Tire [Re: Wookie316] #2370968
09/14/17 10:30 PM
09/14/17 10:30 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
The air Density altitude was bad at SIR last weekend. It was around 4,500 feet and got closer to 5,000 feet near the 3 rd round.
I was able to dial in enough power to still run 9.00's but traction was also not great later in the afternoon.
You will pick up a lot if it gets back down to 3,000 feet where it should be in the fall there...
My 10.5's were definitely spinning as 60 foot slowed from 1.26 down to 1.35.
Nice talking to you in the lanes!
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Big Power, Small Tire [Re: Wookie316] #2370979
09/14/17 10:46 PM
09/14/17 10:46 PM
Alberta
Alberta
Ok. Did not realize the air was that bad on Saturday.
Sunday with the wind I didn't question the numbers I was getting
If our weather don't smarten up, this weekend could be it.
Will run Castrol on Sunday.
Made the final 8 Sunday, well 7 because there was a bi.
With the wind the track had gone away well before then.
I was lucky. The 2 previous rounds I won because they each broke out.
Weather looks good Sunday so we will see what happens.
Great chatting as well. You have a beast of a car.
Re: Big Power, Small Tire [Re: tex013] #2371423
09/15/17 09:17 PM
09/15/17 09:17 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
So I have a question...If your running big power NA and a small tire with a carb, how do you ramp the power in?
Re: Big Power, Small Tire [Re: Dragula] #2371425
09/15/17 09:21 PM
09/15/17 09:21 PM
UMM, lets see, do they really want to share that secret with the rest of the world work whistling shruggy
Many different ways to fix that problem, left foot throttle control, timing and so on shruggy
Re: Big Power, Small Tire [Re: Wookie316] #2371453
09/15/17 10:14 PM
09/15/17 10:14 PM
So. Burlington, Vt.
So. Burlington, Vt.
In the case of the OP, I think he just lets go of the button.
Re: Big Power, Small Tire [Re: Wookie316] #2371521
09/16/17 12:09 AM
09/16/17 12:09 AM
Alberta
Alberta
Yeah that is correct. The power I make sticks as long as suspension is set up and the track has a good prep on it. Now if I was to spray on top that would be a different story.
Re: Big Power, Small Tire [Re: Wookie316] #2372357
09/17/17 08:06 PM
09/17/17 08:06 PM
Alberta
Alberta
So Castrol results different. 60 and MPH /ET same as Hoosiers.
Tried a small 75 shot. Ran a 9.86 with a 1.38 60 at 136 and change. The PBR's worked well. Not much burnout needed. Also ran almost 20 PSI with no issues.
Re: Big Power, Small Tire [Re: Dragula] #2372667
09/18/17 12:49 PM
09/18/17 12:49 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
Use an MSD Power Grid controller to change the timing curve. You can set up a time based retard curve that begins on release of the Trans Brake.
