Re: RIM BLOW STEERING WHEEL REMOVAL
[Re: ahy]
#2360429
08/27/17 01:53 AM
08/27/17 01:53 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I'll just add careful/gentle use of a screwdriver will pry/pop the cap off. Pull the electrical connector (obvious) and remove 3 nuts to pull the wheel. What electrical connector? This is a Rim Blow. The electrical connector needs to be done after the wheel is unbolted usually
[Re: isettakurt]
#2360950
08/28/17 01:26 AM
08/28/17 01:26 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Hello, How Does the Rim Blow Center Cap come off the wheel and how is the Extension tube removed. I do not want to damage anything. There are no diagrams in any of the manuals. Thanks, Kurt Mine pops off easily each time I hit it to honk the horn.
[Re: Sxrxrnr]
#2360963
08/28/17 01:57 AM
08/28/17 01:57 AM
Morty426
Sacramento CA
Hello, How Does the Rim Blow Center Cap come off the wheel and how is the Extension tube removed. I do not want to damage anything. There are no diagrams in any of the manuals. Thanks, Kurt Mine pops off easily each time I hit it to honk the horn. How's that working for ya?
