RIM BLOW STEERING WHEEL REMOVAL #2360093
08/26/17 11:59 AM
08/26/17 11:59 AM
Metro Detroit,Michigan
I
isettakurt Offline OP
I
Hello,
How Does the Rim Blow Center Cap come off the wheel and how is the Extension tube removed. I do not want to damage anything. There are no diagrams in any of the manuals.
Thanks, Kurt
Re: RIM BLOW STEERING WHEEL REMOVAL [Re: isettakurt] #2360131
08/26/17 01:48 PM
08/26/17 01:48 PM
Maryland
MoparMike1974 Offline
Maryland
The center cap just pops off. Under it will be three nuts that hold the steering wheel on. If you want to take the adapter can off there is one nut in the middle that holds it to the steering shaft splines. You will need a puller to remove the can after the nut is removed.
Re: RIM BLOW STEERING WHEEL REMOVAL [Re: isettakurt] #2360167
08/26/17 02:52 PM
08/26/17 02:52 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The extension comes off like a regular steering wheel. Remove the big nut them use a steering wheel puller to remove the extension.
Re: RIM BLOW STEERING WHEEL REMOVAL [Re: Morty426] #2360347
08/26/17 10:31 PM
08/26/17 10:31 PM
IN
ahy Offline
ahy  Offline
IN
I'll just add careful/gentle use of a screwdriver will pry/pop the cap off. Pull the electrical connector (obvious) and remove 3 nuts to pull the wheel.
Re: RIM BLOW STEERING WHEEL REMOVAL [Re: ahy] #2360429
08/27/17 01:53 AM
08/27/17 01:53 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
What electrical connector?
This is a Rim Blow.
The electrical connector needs to be done after the wheel is unbolted usually
Re: RIM BLOW STEERING WHEEL REMOVAL [Re: isettakurt] #2360950
08/28/17 01:26 AM
08/28/17 01:26 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Originally Posted By isettakurt
Hello,
Thanks, Kurt
Mine pops off easily each time I hit it to honk the horn.
Re: RIM BLOW STEERING WHEEL REMOVAL [Re: Sxrxrnr] #2360963
08/28/17 01:57 AM
08/28/17 01:57 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Hello,
Thanks, Kurt
How's that working for ya? laugh
