Re: Bare 6.1 block from Indy?
[Re: MattW]
#2354055
08/15/17 01:59 AM
08/15/17 01:59 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
INDY bought a bunch of defective blocks for dirt cheap from Fiat years AGO. Tread lightly. Matt
That doesn't surprise me, sadly. I called again trying to ask questions and was told "buy one, that will answer all your questions." Then promptly hung up on me. Holy smokes!
[Re: cudadoug]
#2354095
08/15/17 07:57 AM
08/15/17 07:57 AM
Posts: 369 Indy
496 A-body
Indy
Anyone buy a bare 6.1 block from Indy cylinder heads? Seem to be the cheapest on the planet at $995. when I called them he wasn't in the mood for questions. ANY questions...
Seems the going rate elsewhere is $1600-1800, so does anyone know what the catch is?? That ad with the $995 price is very old, 2012 or so. I emailed them about one of those blocks a while back and was quoted $1995, shortly after that I attended the Indy Mopar swap meet and they had one of those blocks in their booth for $2995
[Re: 496 A-body]
#2354860
08/16/17 02:04 PM
08/16/17 02:04 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Seems the going rate elsewhere is $1600-1800, so does anyone know what the catch is?? That ad with the $995 price is very old, 2012 or so. I emailed them about one of those blocks a while back and was quoted $1995, shortly after that I attended the Indy Mopar swap meet and they had one of those blocks in their booth for $2995 For less than 1500.00 you can get a truck AKA Hellcat block right from FIAT already machined. That block will take more that 99.99999% of the abuse most can throw at it! Matt
[Re: cudadoug]
#2355175
08/16/17 11:43 PM
08/16/17 11:43 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
That doesn't surprise me, sadly. I called again trying to ask questions and was told "buy one, that will answer all your questions." Then promptly hung up on me. Holy smokes! Rotflmao
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: cudadoug]
#2355177
08/16/17 11:48 PM
08/16/17 11:48 PM
sixpackgut
Charleston
Ill sell you a 6.1 block for $5k.
It comes with lifters, cam, pistons, rods, crank, timing chain, oil pump, pickup, windage tray, milodan pan. And it was balanced, machined and assembled by the clearance nazi as I use to call him. RIP Dan
[Re: cudadoug]
#2358238
08/22/17 07:27 PM
08/22/17 07:27 PM
Triple Threat
Renton Washington
I'll start the bidding at $1.
I'd probably list it for $2500+ considering its a virgin block with machine work "ready to go" that will help the value.
[Re: cudadoug]
#2358457
08/23/17 07:53 AM
08/23/17 07:53 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Bought a few 6.1s at an estate sale 3 weeks back several blocks a few short blocks and a few crate engines , 2 of the 6.1 blocks had Indy Shipping labels on the crates,...sent both over to the machine shop, deck was fine, crank bore alignment was fine, Block 1 ,Core shift on passenger side bank was not fine, block 2 is ok all way around...Indy = pot luck.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: cudadoug]
#2358458
08/23/17 08:04 AM
08/23/17 08:04 AM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
6.1 blocks are scarce enough that NHRA now allows the use of the aluminum block. Chuck Lofgren reported a significant power increase, and poor 60 fts because the car trips the 60 ft beams with the back tires. Chassis tuning time😀
[Re: ric3xrt]
#2358850
08/24/17 12:07 AM
08/24/17 12:07 AM
Posts: 286 Marysville, OH
mrploww
Marysville, OH
Bought a few 6.1s at an estate sale 3 weeks back several blocks a few short blocks and a few crate engines , 2 of the 6.1 blocks had Indy Shipping labels on the crates,...sent both over to the machine shop, deck was fine, crank bore alignment was fine, Block 1 ,Core shift on passenger side bank was not fine, block 2 is ok all way around...Indy = pot luck. You going to sell any of those 6.1 blocks or engines?
'64 Plymouth Belvedere 9 passenger surf wagon
[Re: mrploww]
#2359022
08/24/17 10:13 AM
08/24/17 10:13 AM
ric3xrt
Trumbauersville PA
Bought a few 6.1s at an estate sale 3 weeks back several blocks a few short blocks and a few crate engines , 2 of the 6.1 blocks had Indy Shipping labels on the crates,...sent both over to the machine shop, deck was fine, crank bore alignment was fine, Block 1 ,Core shift on passenger side bank was not fine, block 2 is ok all way around...Indy = pot luck. You going to sell any of those 6.1 blocks or engines? Honestly I don't know yet.
