#2353272 - 08/13/17 02:08 PM Bare 6.1 block from Indy?
cudadoug Offline
Loc: Between a rock & a hard place
Anyone buy a bare 6.1 block from Indy cylinder heads? Seem to be the cheapest on the planet at $995. when I called them he wasn't in the mood for questions. ANY questions...
Seems the going rate elsewhere is $1600-1800, so does anyone know what the catch is??
#2353280 - 08/13/17 02:35 PM Re: Bare 6.1 block from Indy? [Re: cudadoug]
hudsonhornet7x Online   content
Loc: Plumer, Pa
1. Indy is run by d!ckheads.
2. They must have dropped their price, I called 1.5 years ago and the blocks were 1500 if I remember correctly.
3. It was RUMORED that the blocks Indy has were 2nds and had problems. What problems those were I am unaware of.
If you decide to look for a 6.4 vvt block ( new) please pm me.
XP29H8B198192
#2353313 - 08/13/17 04:33 PM Re: Bare 6.1 block from Indy? [Re: hudsonhornet7x]
fbs63 Offline
Loc: NW Indiana
I seriously doubt they have any 6.1 blocks left. They never update their advertising.
#2353622 - 08/14/17 11:56 AM Re: Bare 6.1 block from Indy? [Re: hudsonhornet7x]
MattW Offline
Loc: Ontario Canada
INDY bought a bunch of defective blocks for dirt cheap from Fiat years AGO. Tread lightly.
Matt
#2353885 - 08/14/17 07:21 PM Re: Bare 6.1 block from Indy? [Re: cudadoug]
Medlock51 Offline
Loc: Wisconsin
What does a 6.2/6.4 block sell for?
#2353945 - 08/14/17 09:18 PM Re: Bare 6.1 block from Indy? [Re: Medlock51]
fbs63 Offline
Loc: NW Indiana
I have a new in the crate 6.2 Hellcat block for $1350.
#2354055 - 08/14/17 11:59 PM Re: Bare 6.1 block from Indy? [Re: MattW]
cudadoug Offline
Matt
That doesn't surprise me, sadly. I called again trying to ask questions and was told "buy one, that will answer all your questions." Then promptly hung up on me. Holy smokes!
#2354092 - 08/15/17 05:24 AM Re: Bare 6.1 block from Indy? [Re: cudadoug]
ric3xrt Offline
Loc: Trumbauersville PA
Indy = Pot luck.
Truth has no agenda, but those with an agenda don't always acknowledge truth
74 D100 D-Code,3x75 D100 D-code, 3x77 D100 D-code,6x78 D150 D-D-code...lots of pre 81 trucks
75 4x2 Ramcharger....G3 coming soon
2003 Ram st
2004 Rumble Bee
2004 Ram GTX(Plum Crazy)
2005 Ram GTXtreme(s Plum Crazy,Banana Yellow)
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building)
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2354095 - 08/15/17 05:57 AM Re: Bare 6.1 block from Indy? [Re: cudadoug]
496 A-body Offline
Loc: Indy
That ad with the $995 price is very old, 2012 or so. I emailed them about one of those blocks a while back and was quoted $1995, shortly after that I attended the Indy Mopar swap meet and they had one of those blocks in their booth for $2995
#2354860 - 08/16/17 12:04 PM Re: Bare 6.1 block from Indy? [Re: 496 A-body]
MattW Offline
Loc: Ontario Canada
For less than 1500.00 you can get a truck AKA Hellcat block right from FIAT already machined.
That block will take more that 99.99999% of the abuse most can throw at it!
Matt
#2355175 - 08/16/17 09:43 PM Re: Bare 6.1 block from Indy? [Re: cudadoug]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
Matt
Rotflmao
#2355177 - 08/16/17 09:48 PM Re: Bare 6.1 block from Indy? [Re: cudadoug]
sixpackgut Offline
Loc: Charleston
Ill sell you a 6.1 block for $5k.
It comes with lifters, cam, pistons, rods, crank, timing chain, oil pump, pickup, windage tray, milodan pan. And it was balanced, machined and assembled by the clearance nazi as I use to call him. RIP Dan
#2355302 - 08/17/17 06:43 AM Re: Bare 6.1 block from Indy? [Re: MattW]
moparmitch Offline
Loc: S.E. Michigan
Get a 6.1 block if you can find a good one at a fair price.
New blocks require a cheesy cam phaser lockout and there's no after market timing sets available to eliminate the cam phasing mechanism and OEM timing chain all together. There's also a specific cam core needed because of the related cam phasing BS that was done to the block.
Has anyone measured the quality/accuracy of the newer OEM machined blocks vs a block machined by a good machine shop?
There's a reason the OEM 6.1 blocks are still in high demand (and very expensive) and why the aluminum performance blocks are based off the 6.1.
Be careful when offered the cool-aid for the newer blocks...
A newer block will work, just be aware of the never ending Mopar band-aids and fixes needed to make something work outside of a production environment.
#2358177 - 08/22/17 03:14 PM Re: Bare 6.1 block from Indy? [Re: cudadoug]
ericlre79 Offline
Loc: Massachusetts
So whats the market value of a as delivered never run, stock bore 6.1 block out of my 2009 Dragpak? I run the 5.7 and the 5.9 magnum so other than using it for a coffee table, it will never get used by me. Eric
#2358238 - 08/22/17 05:27 PM Re: Bare 6.1 block from Indy? [Re: cudadoug]
Triple Threat Offline
Loc: Renton Washington
I'll start the bidding at $1.
I'd probably list it for $2500+ considering its a virgin block with machine work "ready to go" that will help the value.
-Dustin
392" G3 Hemi
1.37, 6.17@111, 9.74@136.9
#2358457 - 08/23/17 05:53 AM Re: Bare 6.1 block from Indy? [Re: cudadoug]
ric3xrt Offline
Bought a few 6.1s at an estate sale 3 weeks back several blocks a few short blocks and a few crate engines , 2 of the 6.1 blocks had Indy Shipping labels on the crates,...sent both over to the machine shop, deck was fine, crank bore alignment was fine, Block 1 ,Core shift on passenger side bank was not fine, block 2 is ok all way around...Indy = pot luck.
2003 Ram st
2004 Rumble Bee
#2358458 - 08/23/17 06:04 AM Re: Bare 6.1 block from Indy? [Re: cudadoug]
gregsdart Offline
Loc: Frostbitefalls (Rocky&Bullwink...
6.1 blocks are scarce enough that NHRA now allows the use of the aluminum block. Chuck Lofgren reported a significant power increase, and poor 60 fts because the car trips the 60 ft beams with the back tires. Chassis tuning time😀
Edited by gregsdart (08/23/17 06:05 AM)
GREG
Educated at SHK U
Measure with yardstick
mark with chalk
cut with torch!
528 cubic inch alky injected 440-1 wedge, 3055 race weight.
8.779 at 153.16 mph. 1.289 60 ft. density altitude 1617 feet. Best 60 ft 1.24
#2358850 - 08/23/17 10:07 PM Re: Bare 6.1 block from Indy? [Re: ric3xrt]
mrploww Offline
Loc: Marysville, OH
You going to sell any of those 6.1 blocks or engines?
'64 Plymouth Belvedere 9 passenger surf wagon
#2359022 - 08/24/17 08:13 AM Re: Bare 6.1 block from Indy? [Re: mrploww]
ric3xrt Offline
Honestly I don't know yet.
2003 Ram st
2004 Rumble Bee
25,383 Registered Members
191,007 Topics
93 Viper door handel ?
by kevin69bman
07/21/18 11:04 PM
RIP Bluebonnet Belle
by BigMoneyLewis
07/21/18 10:28 PM
Boogered up LA valve cover bolt hole - Suggestions?
by GoodysGotaCuda
07/21/18 10:00 PM
Information Binder on Car
by GTXKARL
07/21/18 09:59 PM
