Bare 6.1 block from Indy? #2353272
08/13/17 04:08 PM
08/13/17 04:08 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Anyone buy a bare 6.1 block from Indy cylinder heads? Seem to be the cheapest on the planet at $995. when I called them he wasn't in the mood for questions. ANY questions...
Seems the going rate elsewhere is $1600-1800, so does anyone know what the catch is??
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2353280
08/13/17 04:35 PM
08/13/17 04:35 PM
USA
hudsonhornet7x Online content
hudsonhornet7x  Online Content
USA
1. Indy is run by d!ckheads.
2. They must have dropped their price, I called 1.5 years ago and the blocks were 1500 if I remember correctly.
3. It was RUMORED that the blocks Indy has were 2nds and had problems. What problems those were I am unaware of.
If you decide to look for a 6.4 vvt block ( new) please pm me.
Re: Bare 6.1 block from Indy? [Re: hudsonhornet7x] #2353313
08/13/17 06:33 PM
08/13/17 06:33 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I seriously doubt they have any 6.1 blocks left. They never update their advertising.
Re: Bare 6.1 block from Indy? [Re: hudsonhornet7x] #2353622
08/14/17 01:56 PM
08/14/17 01:56 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
INDY bought a bunch of defective blocks for dirt cheap from Fiat years AGO. Tread lightly.
Matt
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2353885
08/14/17 09:21 PM
08/14/17 09:21 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
What does a 6.2/6.4 block sell for?
Re: Bare 6.1 block from Indy? [Re: Medlock51] #2353945
08/14/17 11:18 PM
08/14/17 11:18 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I have a new in the crate 6.2 Hellcat block for $1350.
Re: Bare 6.1 block from Indy? [Re: MattW] #2354055
08/15/17 01:59 AM
08/15/17 01:59 AM
cudadoug Offline OP
cudadoug  Offline OP
Matt
That doesn't surprise me, sadly. I called again trying to ask questions and was told "buy one, that will answer all your questions." Then promptly hung up on me. Holy smokes!
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2354092
08/15/17 07:24 AM
08/15/17 07:24 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Indy = Pot luck.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2354095
08/15/17 07:57 AM
08/15/17 07:57 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
That ad with the $995 price is very old, 2012 or so. I emailed them about one of those blocks a while back and was quoted $1995, shortly after that I attended the Indy Mopar swap meet and they had one of those blocks in their booth for $2995
Re: Bare 6.1 block from Indy? [Re: 496 A-body] #2354860
08/16/17 02:04 PM
08/16/17 02:04 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
For less than 1500.00 you can get a truck AKA Hellcat block right from FIAT already machined.
That block will take more that 99.99999% of the abuse most can throw at it!
Matt
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2355175
08/16/17 11:43 PM
08/16/17 11:43 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Matt
Rotflmao
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2355177
08/16/17 11:48 PM
08/16/17 11:48 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Ill sell you a 6.1 block for $5k.
It comes with lifters, cam, pistons, rods, crank, timing chain, oil pump, pickup, windage tray, milodan pan. And it was balanced, machined and assembled by the clearance nazi as I use to call him. RIP Dan
Re: Bare 6.1 block from Indy? [Re: MattW] #2355302
08/17/17 08:43 AM
08/17/17 08:43 AM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Get a 6.1 block if you can find a good one at a fair price.
New blocks require a cheesy cam phaser lockout and there's no after market timing sets available to eliminate the cam phasing mechanism and OEM timing chain all together. There's also a specific cam core needed because of the related cam phasing BS that was done to the block.
Has anyone measured the quality/accuracy of the newer OEM machined blocks vs a block machined by a good machine shop?
There's a reason the OEM 6.1 blocks are still in high demand (and very expensive) and why the aluminum performance blocks are based off the 6.1.
Be careful when offered the cool-aid for the newer blocks...
A newer block will work, just be aware of the never ending Mopar band-aids and fixes needed to make something work outside of a production environment.
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2358177
08/22/17 05:14 PM
08/22/17 05:14 PM
Massachusetts
E
ericlre79 Offline
ericlre79  Offline
E
Massachusetts
So whats the market value of a as delivered never run, stock bore 6.1 block out of my 2009 Dragpak? I run the 5.7 and the 5.9 magnum so other than using it for a coffee table, it will never get used by me. Eric
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2358238
08/22/17 07:27 PM
08/22/17 07:27 PM
Renton Washington
Triple Threat Offline
Renton Washington
I'll start the bidding at $1.
I'd probably list it for $2500+ considering its a virgin block with machine work "ready to go" that will help the value.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2358457
08/23/17 07:53 AM
08/23/17 07:53 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Bought a few 6.1s at an estate sale 3 weeks back several blocks a few short blocks and a few crate engines , 2 of the 6.1 blocks had Indy Shipping labels on the crates,...sent both over to the machine shop, deck was fine, crank bore alignment was fine, Block 1 ,Core shift on passenger side bank was not fine, block 2 is ok all way around...Indy = pot luck.
Re: Bare 6.1 block from Indy? [Re: cudadoug] #2358458
08/23/17 08:04 AM
08/23/17 08:04 AM
gregsdart Offline
gregsdart  Offline
6.1 blocks are scarce enough that NHRA now allows the use of the aluminum block. Chuck Lofgren reported a significant power increase, and poor 60 fts because the car trips the 60 ft beams with the back tires. Chassis tuning time😀
Re: Bare 6.1 block from Indy? [Re: ric3xrt] #2358850
08/24/17 12:07 AM
08/24/17 12:07 AM
Marysville, OH
mrploww Offline
mrploww  Offline
Marysville, OH
You going to sell any of those 6.1 blocks or engines?
'64 Plymouth Belvedere 9 passenger surf wagon
Re: Bare 6.1 block from Indy? [Re: mrploww] #2359022
08/24/17 10:13 AM
08/24/17 10:13 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Honestly I don't know yet.
