How does pulley come off of Federal power steering pump? #2352685
08/12/17 12:56 AM
08/12/17 12:56 AM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Is it pressed on? What is the threaded hole in the shaft for?
Re: How does pulley come off of Federal power steering pump? [Re: 6pkaar] #2352725
08/12/17 05:57 AM
08/12/17 05:57 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Pressed on, the threaded whole is for the correct tool to re-install which I have here that I use.
https://tinyurl.com/y7crbyy4
Re: How does pulley come off of Federal power steering pump? [Re: 6pkaar] #2352764
08/12/17 11:19 AM
08/12/17 11:19 AM
VA
dragon slayer Offline
VA
You use the tool shown or an appropriate puller to remove the pulley. The threads are for reinstalling because the pump assembly internals are sensitive to position and if you try to press the pulley on you can dislodge the back of the pump and it will not prime or pump fluid. The threaded tool engages the shaft and you are pulling the pulley on to the shaft without effecting the pump assembly.
Re: How does pulley come off of Federal power steering pump? [Re: HEMICUDA] #2352769
08/12/17 11:34 AM
08/12/17 11:34 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I couldn't help myself, I'm a tool addict, I bought one. whiney
Re: How does pulley come off of Federal power steering pump? [Re: 6PakBee] #2352773
08/12/17 11:39 AM
08/12/17 11:39 AM
GMP440 Offline
GMP440  Offline
Excellant tool to remove pulleys. Used to borrow this from a friend of mine. Been waiting for Harbor Freight to do a price drop on these.
Re: How does pulley come off of Federal power steering pump? [Re: 6pkaar] #2353010
08/12/17 10:34 PM
08/12/17 10:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This !
