Re: How does pulley come off of Federal power steering pump?
[Re: 6pkaar]
#2352725
08/12/17 05:57 AM
08/12/17 05:57 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Pressed on, the threaded whole is for the correct tool to re-install which I have here that I use. https://tinyurl.com/y7crbyy4
[Re: 6pkaar]
#2352764
08/12/17 11:19 AM
08/12/17 11:19 AM
Posts: 1,321 VA
dragon slayer
VA
You use the tool shown or an appropriate puller to remove the pulley. The threads are for reinstalling because the pump assembly internals are sensitive to position and if you try to press the pulley on you can dislodge the back of the pump and it will not prime or pump fluid. The threaded tool engages the shaft and you are pulling the pulley on to the shaft without effecting the pump assembly.
