Re: Would you put AC in a 'vert?
[Re: phantomx]
#235025
02/25/09 04:10 AM
02/25/09 04:10 AM
Posts: 26,561 Santa Rosa, NOR*CAL.
Just Cameron
If you plan to drive it further than around town, I say do it. Travis..
Of course you do...You live in the Valley.
That being said when I was in Davis the Duster still didn't have A/C...Neither did the black '55 Buick. The girlfriend's '97 Mitsubishi 1.5 did, but it sucked so much power I just sweated and dealt with it.
[Re: challenger70]
#235034
02/25/09 01:07 PM
02/25/09 01:07 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I vote for AC allways... vert cars with top up are MORE HOT inside than regulars hardtops
then if you want to turn on or not, is your problem but will have the option.
AC is necesary specially on rainy days. Is false the vent or deffog keeps the same exterior temperature inside, so you gets fog inside ALLWAYS.
[Re: 6pkaar]
#235035
02/25/09 01:14 PM
02/25/09 01:14 PM
No, I got a 67 'cuda vert and have driven it for several years without A/C (it came that way). I don't miss it one bit, but then again I like cars with manual windows, manual locks, manual tranmission and a carb on top of the engine! Bob ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: 6pkaar]
#235036
02/25/09 02:14 PM
02/25/09 02:14 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Yes Perfect Top down weather is below 80f anything more you can put the top up and a/c on on or top down and A/C on to maybe 85f ![](/ubbthreads/images/graemlins/thumbs.gif)
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: 6pkaar]
#235038
02/25/09 02:42 PM
02/25/09 02:42 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
[quote Is this a real 1970 'Cuda convertible with a 'Cuda vin and data plate?
No, it's not a 'Cuda, it's a Barracuda. Originally a 318 / automatic car. When I bought the car it had a non running 360 in it. It needs LOTS of metal work. I'm going to get shot down for this....but I figured I might as well make yet another 'Cuda "clone". Just tossing around the idea of adding air while I'm at it. One day it sounds like a great idea, the next I figure it's not worth the hassle. So I thought I'd get the opinion of guys that have 'verts with and without air and if they use it or wish they had it.
In that case, let the freon fly!!! Go for it.
[Re: CYACOP]
#235040
02/25/09 04:34 PM
02/25/09 04:34 PM
Posts: 38 Joliet, IL Area
tranch
Joliet, IL Area
Northerners say no. Southerners say yes. Looks like you're stuck somewhere in the middle.
Let me add a comment from "The Middle!" Here in the midwest, Chicago Area, the humidity can be higher than the temperature and raining! Makes the interior of your car like a steam room! It's not a numbers matching, concours restoration, and, most importantly IT'S YOURS so do what YOU want to do with the car and don't worry what others tell you. If the A/C install is done correctly it's going to enhance the value of the car anyway! ![](/ubbthreads/images/graemlins/thumbs.gif)
