73 Roadrunner won't always start in park. Use Neutral.
#2349928
08/07/17 08:27 AM
08/07/17 08:27 AM
Posts: 158 Poland, Ohio 44514
captainjack
Poland, Ohio 44514
73 Plymouth Roadrunner 318 c.i. will not always start in Park. I must use
neutral. Does this intermittently. I have replaced the Neutral starting
switch. Anyone have ab idea of what I need to repair to correct??
THANK"S for the add MOPARTS. PM me or e mail at moparjack67@sbcglobaal.
net. Ask for JACK.
Re: 73 Roadrunner won't always start in park. Use Neutral.
[Re: captainjack]
#2349934
08/07/17 08:56 AM
08/07/17 08:56 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Tranny linkage adjustment or roostercomb isolation into the tranny "failure"
[Re: NachoRT74]
#2350040
08/07/17 01:40 PM
08/07/17 01:40 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Tranny linkage adjustment or roostercomb isolation into the tranny "failure" Agreed...Those are the two common issues...You can also check the linkage for excessive wear and slop during movement...
[Re: screamindriver]
#2350066
08/07/17 02:19 PM
08/07/17 02:19 PM
RapidRobert
next time it does it I would pull the connector off of the NSS switch on the side of the trans & see if the middle pin has continuity to the nearby trans metal case. If it does not then as said I would undo the linkage from the lever & with the lever firmly in the park & neutral detents see if it now has continuity. if in the first case the middle pin has continuity then I would check the electrical connectors starting with the NSS plug in connector & all the way up to the starter relay for a poor connection. most all wiring continuity problems are at the terminals/connections.
[Re: captainjack]
#2350165
08/07/17 04:40 PM
08/07/17 04:40 PM
Posts: 106 waco tx
gogo318
waco tx
Sweet info my 74 satelite dose this ive dealt with it for years !!!!
67 charger fastback 318 stock
67 belvedere II 4dr soft top built 318
68 newport 2dr hard top 318
84 b150 440/727
84 d150 short wheel step side 4x4 lifted
87 omnitruck (you just have to see it )
new addition 63 dart wagon !!!
[Re: gogo318]
#2350289
08/07/17 08:42 PM
08/07/17 08:42 PM
Posts: 25,822 Rio Linda, CA
John_Kunkel
Rio Linda, CA
This is usually the culprit....worn or missing.
[Re: captainjack]
#2350724
08/08/17 02:31 PM
08/08/17 02:31 PM
NachoRT74
Valencia, España
This is the piece inside the tranny. The unconvered points gives the ground to the point at NSS on P and N http://www.forabodiesonly.com/mopar/attachments/image-jpg.1714797403/ That piece engages to the tranny linkage ( despite the application legend, works te same in all cars ) http://cdn6.bigcommerce.com/s-401bd/prod...pg?t=1448733765If linkage is not correctly adjusted, the points won't meet between NSS and roostercomb lever hence won't source the ground to the starter relay. Now, you can get some dirty the points inside, worn, linkage play or due worn or missed pieces like the bushing mentioned, or simply needing to be readjusted
