73 Roadrunner won't always start in park. Use Neutral. #2349928
08/07/17 08:27 AM
08/07/17 08:27 AM
Poland, Ohio 44514
captainjack Offline OP
Poland, Ohio 44514
73 Plymouth Roadrunner 318 c.i. will not always start in Park. I must use
neutral. Does this intermittently. I have replaced the Neutral starting
switch. Anyone have ab idea of what I need to repair to correct??
THANK"S for the add MOPARTS. PM me or e mail at moparjack67@sbcglobaal.
net. Ask for JACK.
Re: 73 Roadrunner won't always start in park. Use Neutral. [Re: captainjack] #2349934
08/07/17 08:56 AM
08/07/17 08:56 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Tranny linkage adjustment or roostercomb isolation into the tranny "failure"
Re: 73 Roadrunner won't always start in park. Use Neutral. [Re: NachoRT74] #2350040
08/07/17 01:40 PM
08/07/17 01:40 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Agreed...Those are the two common issues...You can also check the linkage for excessive wear and slop during movement...
Re: 73 Roadrunner won't always start in park. Use Neutral. [Re: screamindriver] #2350066
08/07/17 02:19 PM
08/07/17 02:19 PM
next time it does it I would pull the connector off of the NSS switch on the side of the trans & see if the middle pin has continuity to the nearby trans metal case. If it does not then as said I would undo the linkage from the lever & with the lever firmly in the park & neutral detents see if it now has continuity. if in the first case the middle pin has continuity then I would check the electrical connectors starting with the NSS plug in connector & all the way up to the starter relay for a poor connection. most all wiring continuity problems are at the terminals/connections.
Re: 73 Roadrunner won't always start in park. Use Neutral. [Re: captainjack] #2350165
08/07/17 04:40 PM
08/07/17 04:40 PM
waco tx
gogo318 Offline
gogo318  Offline
waco tx
Sweet info my 74 satelite dose this ive dealt with it for years !!!!
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: 73 Roadrunner won't always start in park. Use Neutral. [Re: gogo318] #2350289
08/07/17 08:42 PM
08/07/17 08:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This is usually the culprit....worn or missing.
Re: 73 Roadrunner won't always start in park. Use Neutral. [Re: John_Kunkel] #2350553
08/08/17 09:38 AM
08/08/17 09:38 AM
Poland, Ohio 44514
Poland, Ohio 44514
Greetings: I changed the neutral starting switch and it did not make a difference. This gearshift linkage torque shaft bushing goes where. Do you have a picture from a service manual? Is there only one or two. I
am not the wrench man. If you could provide more info would be helpful.
THANKS so much for this info. You can e mail me at moparjack67@sbcglobal.net or cell phone 330-719-0606. Jack Gocala
Re: 73 Roadrunner won't always start in park. Use Neutral. [Re: captainjack] #2350642
08/08/17 12:28 PM
08/08/17 12:28 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
It goes in the hole on the bracket bolted on the side of the transmission. The end of the shaft from the frame bracket goes inside that bushing. It uses just one, at least I can't remember there being one on the frame bracket, been too long since I messed with all that. If you can't find one my brother used a short piece of garden hose. work
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 73 Roadrunner won't always start in park. Use Neutral. [Re: captainjack] #2350724
08/08/17 02:31 PM
08/08/17 02:31 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
This is the piece inside the tranny. The unconvered points gives the ground to the point at NSS on P and N
http://www.forabodiesonly.com/mopar/attachments/image-jpg.1714797403/
That piece engages to the tranny linkage ( despite the application legend, works te same in all cars )
http://cdn6.bigcommerce.com/s-401bd/prod...pg?t=1448733765
If linkage is not correctly adjusted, the points won't meet between NSS and roostercomb lever hence won't source the ground to the starter relay.
Now, you can get some dirty the points inside, worn, linkage play or due worn or missed pieces like the bushing mentioned, or simply needing to be readjusted
