What small block Mopar electric water pump to use? #2349783
08/06/17 11:17 PM
08/06/17 11:17 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
While at Monster Mopar I ran three classes, two were back to back, and I need to be able to do some quick cooling down.
I tried the belt driven electric motor on the water pump (Moroso) but it lasted 2 passes before the motor fried on it (last year).
What do you guys recommend?
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349787
08/06/17 11:20 PM
08/06/17 11:20 PM
Washington
madscientist Offline
Washington
Does it have to be electric? Running like that I'd rather have a high flow water pump, overdriven turned by a belt.
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349789
08/06/17 11:21 PM
08/06/17 11:21 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Husband said he wants electric.
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349793
08/06/17 11:26 PM
08/06/17 11:26 PM
Washington
Washington
Damn. If my wife listened like that, I'd have an alcohol funny car!
Well, in that case, I've used the Miezere (sp) pump. I can't remember the GPM but it was the biggest I could find.
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349814
08/06/17 11:49 PM
08/06/17 11:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Messier is a top not product with great service. I have had one for about 18 years and it has needed service once.
68 Barracuda Formula S 340
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349829
08/07/17 12:14 AM
08/07/17 12:14 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Merziere is top notch, but if you're looking to save a few bucks I've had good luck with Proform. That and a Champion 2 core radiator keep my iron headed 408 under 170 degrees on the street and plenty cool at the track.
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349830
08/07/17 12:17 AM
08/07/17 12:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Have Meziere on both mills.... and I'd do it again smile
https://www.meziere.com/
running lots of classes? go BIG on the radiator. I also have my water pump and electric fans wired into and extension cord plug. Hook it up to a deep cycle battery while in the pits. That was I can cool all I want and not beat up on my primary battery.
Re: What small block Mopar electric water pump to use? [Re: J_BODY] #2349843
08/07/17 12:42 AM
08/07/17 12:42 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I would recommend this with a good electric fan. This will help keep it simple.. bolt up and go.. https://m.summitracing.com/parts/mor-635...4saAtPBEALw_wcB
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: What small block Mopar electric water pump to use? [Re: WHITEDART] #2349851
08/07/17 12:57 AM
08/07/17 12:57 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have that one and like it.
Key thing is between round cooldown not running down your battery.
I like the idea Jbody had in his post, using a spare battery.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349920
08/07/17 05:13 AM
08/07/17 05:13 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
How tight did you have the belt on the Moroso? Tight belt will kill those little motors.
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349939
08/07/17 09:50 AM
08/07/17 09:50 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I like my Meziere pump, trouble free for years.
To save a little room on the front of my motor I did a little welding and milled off the water pump recess. That way I did not need to use a block off plate. Saved about 3/4" and a little weight
"Just a Bracket car dressed up like a streetcar"
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349955
08/07/17 10:48 AM
08/07/17 10:48 AM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
I've used the moroso billet electric one for about 3 years now. No problems ever.
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2349959
08/07/17 10:54 AM
08/07/17 10:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Meziere is a great company with excellent customer service. I would go that way with a good electric fan and shroud if possible.
Bill
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350054
08/07/17 02:05 PM
08/07/17 02:05 PM
Locomotion Offline
Locomotion  Offline
Whatever electric pump you use, make sure you have VERY GOOD grounds.
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350055
08/07/17 02:05 PM
08/07/17 02:05 PM
Renton Washington
Triple Threat Offline
Renton Washington
Meziere
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What small block Mopar electric water pump to use? [Re: madscientist] #2350176
08/07/17 04:58 PM
08/07/17 04:58 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
lol! he's my crew chief, so I have to listen to him. Plus he's my favorite person in the world.
Re: What small block Mopar electric water pump to use? [Re: slantzilla] #2350177
08/07/17 04:58 PM
08/07/17 04:58 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Probably too tight! Good to know, thanks!
Re: What small block Mopar electric water pump to use? [Re: Locomotion] #2350178
08/07/17 04:59 PM
08/07/17 04:59 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
we'll do that.
Thanks guys!
Re: What small block Mopar electric water pump to use? [Re: dustergirl340] #2350188
08/07/17 05:07 PM
08/07/17 05:07 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have been running a ProForm on my small block for around 5 years on the street and track. It cools down quick between rounds and keeps it cool on the street.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: What small block Mopar electric water pump to use? [Re: D-50] #2350229
08/07/17 06:23 PM
08/07/17 06:23 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
I run the meziere that mounts on radiator and I love it!
