Re: What small block Mopar electric water pump to use?
[Re: dustergirl340]
#2349787
08/06/17 11:20 PM
08/06/17 11:20 PM
Posts: 4,457 Washington
madscientist
Washington
While at Monster Mopar I ran three classes, two were back to back, and I need to be able to do some quick cooling down.
I tried the belt driven electric motor on the water pump (Moroso) but it lasted 2 passes before the motor fried on it (last year).
What do you guys recommend? Does it have to be electric? Running like that I'd rather have a high flow water pump, overdriven turned by a belt.
[Re: dustergirl340]
#2349793
08/06/17 11:26 PM
08/06/17 11:26 PM
madscientist
Washington
Husband said he wants electric. Damn. If my wife listened like that, I'd have an alcohol funny car! Well, in that case, I've used the Miezere (sp) pump. I can't remember the GPM but it was the biggest I could find.
[Re: dustergirl340]
#2349814
08/06/17 11:49 PM
08/06/17 11:49 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Messier is a top not product with great service. I have had one for about 18 years and it has needed service once.
68 Barracuda Formula S 340
[Re: WHITEDART]
#2349851
08/07/17 12:57 AM
08/07/17 12:57 AM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
I have that one and like it. Key thing is between round cooldown not running down your battery. I like the idea Jbody had in his post, using a spare battery.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: dustergirl340]
#2349920
08/07/17 05:13 AM
08/07/17 05:13 AM
Posts: 20,187 Park Forest, IL
slantzilla
Park Forest, IL
How tight did you have the belt on the Moroso? Tight belt will kill those little motors.
[Re: dustergirl340]
#2349939
08/07/17 09:50 AM
08/07/17 09:50 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I like my Meziere pump, trouble free for years.
To save a little room on the front of my motor I did a little welding and milled off the water pump recess. That way I did not need to use a block off plate. Saved about 3/4" and a little weight
"Just a Bracket car dressed up like a streetcar"
[Re: madscientist]
#2350176
08/07/17 04:58 PM
08/07/17 04:58 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
lol! he's my crew chief, so I have to listen to him. Plus he's my favorite person in the world.
[Re: slantzilla]
#2350177
08/07/17 04:58 PM
08/07/17 04:58 PM
dustergirl340
Chicken Little
Chicken Little
Chicken coop
How tight did you have the belt on the Moroso? Tight belt will kill those little motors. Probably too tight! Good to know, thanks!
[Re: Locomotion]
#2350178
08/07/17 04:59 PM
08/07/17 04:59 PM
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Whatever electric pump you use, make sure you have VERY GOOD grounds. we'll do that. Thanks guys!
[Re: dustergirl340]
#2350188
08/07/17 05:07 PM
08/07/17 05:07 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have been running a ProForm on my small block for around 5 years on the street and track. It cools down quick between rounds and keeps it cool on the street.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
