Small Block Engine Bracket Question #2349131
08/05/17 07:33 PM
08/05/17 07:33 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
A friend was attempting to install a pair of small block motor mount brackets on his 360 motor and experienced an issue with mating the bracket to the bosses. Disregard the bolts... It appears the LH mount ear contains a hole at the bottom as opposed to the top. Any idea what this bracket is for? An early small block (273 or 318)? He said this was 1978 truck 360 block.
Re: Small Block Engine Bracket Question [Re: vinnyd76] #2349145
08/05/17 08:35 PM
08/05/17 08:35 PM
CA
crackedback Offline
crackedback  Offline
CA
That's a 273/318 bracket.
You either need to find a driver side 340-360 bracket or weld a piece of metal onto that one you have capturing the block upper bolt ear.
You can also section the bracket, moving that low position hole to the upper spot. I do it all the time with those brackets.
Re: Small Block Engine Bracket Question [Re: crackedback] #2349256
08/06/17 12:46 AM
08/06/17 12:46 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
what he said.
Tony
70 AARCuda Vitamin C
Re: Small Block Engine Bracket Question [Re: 70AARcuda] #2349359
08/06/17 11:04 AM
08/06/17 11:04 AM
moparx Offline
moparx  Offline
in the old direct connection engine manuals, there was a diagram with the dimensions for a triangular plate to be welded to 318 brackets, converting them to the 340/360 block ears. this may also be in the later mopar performance books, but i don't know for sure, as i do not own any of those. if you want, i can look up that diagram for you.
beer
Re: Small Block Engine Bracket Question [Re: vinnyd76] #2349367
08/06/17 11:25 AM
08/06/17 11:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Small Block Engine Bracket Question [Re: vinnyd76] #2349929
08/07/17 08:37 AM
08/07/17 08:37 AM
STL
cdstl Offline
cdstl  Offline
STL
We were attempting to put a 360 into a 318 70 Duster. The 318 PS mount worked but the DS was like yours. DS mounts are near unobtanium status.
I ended up calling Schumacher and they sold me just the DS mount. About $70. It appears that they may be out of stock, I'd give them a call.
Schumacher
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Small Block Engine Bracket Question [Re: cdstl] #2349943
08/07/17 10:01 AM
08/07/17 10:01 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you can't find one I probably have one. If you need a picture of the ones I have let me know. If one will work for you how does 25.00 plus shipping sound. Pm me if interested. John
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block Engine Bracket Question [Re: vinnyd76] #2349989
08/07/17 11:54 AM
08/07/17 11:54 AM
Earth
Rob C Offline
Rob C  Offline
Earth
We used to just use spare nuts to take up the room.....
Re: Small Block Engine Bracket Question [Re: vinnyd76] #2349997
08/07/17 12:15 PM
08/07/17 12:15 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Other than the above mod the IIRC the bracket goes on the other side of the boss, never mind you have it right!
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
