Re: Small Block Engine Bracket Question
[Re: crackedback]
#2349256
08/06/17 12:46 AM
08/06/17 12:46 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
That's a 273/318 bracket.
You either need to find a driver side 340-360 bracket or weld a piece of metal onto that one you have capturing the block upper bolt ear.
You can also section the bracket, moving that low position hole to the upper spot. I do it all the time with those brackets. what he said.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: vinnyd76]
#2349929
08/07/17 08:37 AM
08/07/17 08:37 AM
Posts: 1,487 STL
cdstl
STL
We were attempting to put a 360 into a 318 70 Duster. The 318 PS mount worked but the DS was like yours. DS mounts are near unobtanium status. I ended up calling Schumacher and they sold me just the DS mount. About $70. It appears that they may be out of stock, I'd give them a call. Schumacher
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: cdstl]
#2349943
08/07/17 10:01 AM
08/07/17 10:01 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you can't find one I probably have one. If you need a picture of the ones I have let me know. If one will work for you how does 25.00 plus shipping sound. Pm me if interested. John
[Re: vinnyd76]
#2349997
08/07/17 12:15 PM
08/07/17 12:15 PM
Posts: 2,833 Connecticut
FurryStump
Connecticut
Other than the above mod the IIRC the bracket goes on the other side of the boss, never mind you have it right!
