Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth!
[Re: 57Fury440]
#2348664
08/04/17 09:15 PM
08/04/17 09:15 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
I'm pretty sure Chrysler Corp. in Canada sold Plymouths with Dodge fronts. Well that would be good news. I should know if I can get it cheap and by cheap Im talking 200 max. For that and with my dodge, I could build a dirt cheap rig.
[Re: 57Fury440]
#2348725
08/04/17 11:20 PM
08/04/17 11:20 PM
Posts: 237 British Columbia, Canada
Old Ray
I'm pretty sure Chrysler Corp. in Canada sold Plymouths with Dodge fronts. Yes, they did, and were sold as Dodges (as a cost saver). Nicknamed a Plodge. I have one. Dodge grille, Plymouth dash. It is my understanding that the front fenders where special to mate the two.
[Re: Old Ray]
#2348742
08/04/17 11:39 PM
08/04/17 11:39 PM
RUMBLON
Cambridge Idaho
I'm pretty sure Chrysler Corp. in Canada sold Plymouths with Dodge fronts. Yes, they did, and were sold as Dodges (as a cost saver). Nicknamed a Plodge. I have one. Dodge grille, Plymouth dash. It is my understanding that the front fenders where special to mate the two. ughhhhhhhhhhh RUMBLON
[Re: RUMBLON]
#2348746
08/04/17 11:52 PM
08/04/17 11:52 PM
Posts: 10,566 Freeport IL USA
poorboy
Freeport IL USA
According to the Standard catalog of Chrysler 1924-1990: 56 Plymouth (all models) had a 115" wheel base and an over all length of 204.8"
56 Dodge had 120" wheel base, and had an over all length of 213".
It was pretty typical of a Dodge to have a longer front end then a Plymouth had. You may have to alter the rear edge of the Dodge front fenders to match up with the Plymouth wheel base.
Its an old car, a torch and a welder can put nearly anything together.
I type slow! 57 was the introduction of the unibody construction. Both 56's should be body on frame. A Dakota front end has been put under at least one of these cars, I think its story is right here on Moparts. Its not a simple job. Gene
[Re: RUMBLON]
#2349169
08/05/17 09:44 PM
08/05/17 09:44 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Thanks, Im starting to think it may work by the looks of these.
56 DODGE REGENTS
OBVIOUS PLYMOUTH BACK HALF AND DODGE FRONT CLIPS
My first car was a 56 Plodge Regent the same colour combo as that in a 2dr hardtop. Flathead Powerflite. Long on flat, short on power. I did find out that if you stand on one for several minutes it will hit 100 MPH eventually... Broke the crank at the rear main after I lifted. Kevin
[Re: poorboy]
#2355301
08/17/17 08:32 AM
08/17/17 08:32 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I type slow! 57 was the introduction of the unibody construction. Both 56's should be body on frame. A Dakota front end has been put under at least one of these cars, I think its story is right here on Moparts. Its not a simple job. Gene 1960 was the first year for uni-body.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
