Any chance a 56 Dodge front clip will fit a 56 Plymouth! #2348571
08/04/17 06:26 PM
08/04/17 06:26 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
So I found whats left of a 56 plymouth 2 DR POST that may be for sale cheap.
Just so happens that I have a 56 Dodge sitting here.
I dont think it will swap out but just for kicks I thought I would ask.
RUMBLON
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: RUMBLON] #2348572
08/04/17 06:30 PM
08/04/17 06:30 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
DODGE
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: RUMBLON] #2348578
08/04/17 06:44 PM
08/04/17 06:44 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Maybe change one of the tail lights also, just one side. grin How about cut the grill and front bumper in half and swap those. work
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: amxautox] #2348641
08/04/17 08:35 PM
08/04/17 08:35 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
I'm pretty sure Chrysler Corp. in Canada sold Plymouths with Dodge fronts.
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: 57Fury440] #2348664
08/04/17 09:15 PM
08/04/17 09:15 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Well that would be good news. I should know if I can get it cheap and by cheap Im talking 200 max.
For that and with my dodge, I could build a dirt cheap rig.
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: RUMBLON] #2348703
08/04/17 10:35 PM
08/04/17 10:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: Supercuda] #2348724
08/04/17 11:19 PM
08/04/17 11:19 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thanks, Im starting to think it may work by the looks of these.
56 DODGE REGENTS
OBVIOUS PLYMOUTH BACK HALF AND DODGE FRONT CLIPS
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: 57Fury440] #2348725
08/04/17 11:20 PM
08/04/17 11:20 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
Yes, they did, and were sold as Dodges (as a cost saver). Nicknamed a Plodge. I have one. Dodge grille, Plymouth dash. It is my understanding that the front fenders where special to mate the two.
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: Old Ray] #2348742
08/04/17 11:39 PM
08/04/17 11:39 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
ughhhhhhhhhhh
RUMBLON
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: RUMBLON] #2348745
08/04/17 11:48 PM
08/04/17 11:48 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Are these rigs unibody or do the bodies come off and if they come off do you think they would fit on a Dakota for a swap?
I have a great running 92 Dakota 318 magnum.
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: RUMBLON] #2348746
08/04/17 11:52 PM
08/04/17 11:52 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
According to the Standard catalog of Chrysler 1924-1990:
56 Plymouth (all models) had a 115" wheel base and an over all length of 204.8"
56 Dodge had 120" wheel base, and had an over all length of 213".
It was pretty typical of a Dodge to have a longer front end then a Plymouth had. You may have to alter the rear edge of the Dodge front fenders to match up with the Plymouth wheel base.
Its an old car, a torch and a welder can put nearly anything together.
I type slow! 57 was the introduction of the unibody construction. Both 56's should be body on frame. A Dakota front end has been put under at least one of these cars, I think its story is right here on Moparts. Its not a simple job. Gene
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: RUMBLON] #2349169
08/05/17 09:44 PM
08/05/17 09:44 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
56 DODGE REGENTS
My first car was a 56 Plodge Regent the same colour combo as that in a 2dr hardtop.
Flathead Powerflite. Long on flat, short on power. I did find out that if you stand on one for several minutes it will hit 100 MPH eventually... Broke the crank at the rear main after I lifted.
Kevin
Re: Any chance a 56 Dodge front clip will fit a 56 Plymouth! [Re: poorboy] #2355301
08/17/17 08:32 AM
08/17/17 08:32 AM
jersey
Spaceman Spiff Offline
jersey
1960 was the first year for uni-body.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
