Page 1 of 4 1 2 3 4
Oil change and now no oil pressure! #2345759
07/30/17 04:23 PM
07/30/17 04:23 PM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
I just did an oil and filter change and now there is no oil pressure. The gauge worked just prior to the oil change. I have lots of oil in the pan. No leaks either. What should I look for?
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345767
07/30/17 04:32 PM
07/30/17 04:32 PM
Andrewh Offline
Andrewh  Offline
what oil filter?
any other work while you were doing that?
Re: Oil change and now no oil pressure! [Re: Andrewh] #2345770
07/30/17 04:39 PM
07/30/17 04:39 PM
mechanical or electrical gauge? if electrical is there any possibility a wire got bumped loose? are the lifters clattering? Lastly you might pull the filter & even cranking or starting it for several seconds to see if it is pumping (on that one hopefully a BB or a SB with the 90 deg adapter so you can put a bag over it!. holler how it goes/what it ends up being.
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345772
07/30/17 04:45 PM
07/30/17 04:45 PM
Ontario, Canada
500ciBee Offline OP
500ciBee  Offline OP
Ontario, Canada
No other work done. Just oIL and filter. I put a Fram PH8A on. Car has a mechanical gauge. I let it run for 25 seconds or so and the gauge didn't move. I primed the filter before putting it on. The filter is warm to the touch.
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345775
07/30/17 04:50 PM
07/30/17 04:50 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
do not run past 10 seconds. damages bearings. pull dist and drive gear and turn pump with drill motor. try different gauge.
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345776
07/30/17 04:51 PM
07/30/17 04:51 PM
To Keep It Simple Sam, it sounds like a bad filter (not sure exactly how it is plugged or partly plugging up tho). I would suggest a Wix. EDIT yes hand fill the new filter up first, as you know it'll take a few minutes for it to settle so you get it as full as you can
Re: Oil change and now no oil pressure! [Re: RapidRobert] #2345780
07/30/17 05:09 PM
07/30/17 05:09 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Any strange noises? Check the connection on the sending unit, mine slipped off on one of my 440s, scared the daylights out of me when I saw 0 lbs, put it back on...all good...just a quickie unless filter is bad....
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345781
07/30/17 05:10 PM
07/30/17 05:10 PM
BlueRacer69 Offline
BlueRacer69  Offline
Check the oil gauge's line between the engine and the gauge. Also try a different oil filter. I recommend a Wix or a Napa Gold filter. You didn't say what type of oil you put in it?
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345782
07/30/17 05:11 PM
07/30/17 05:11 PM
Andrewh Offline
Andrewh  Offline
I would spend 6 bucks and slap on a new filter first.
If it doesn't fix it then, I would do as sugguested and do the drill method to prime the motor and see if you are getting oil so you don't damage anything without pressure.
The fact that it is warm means some flow, but doesn't mean enough.
Re: Oil change and now no oil pressure! [Re: Andrewh] #2345784
07/30/17 05:17 PM
07/30/17 05:17 PM
^^^ this, & the warm temp sure sounds like it is partly plugged up.
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345790
07/30/17 05:32 PM
07/30/17 05:32 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Heard this happen with Fram filters.Not saying its the problem. But I used to run them.Do not anymore. I run k&Ns on my 440.Rockyu
Chrysler Firepower
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345794
07/30/17 05:33 PM
07/30/17 05:33 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
After changing filters, and getting pressure, cut open the fram and tell us what's wrong with it. :-)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345806
07/30/17 05:59 PM
07/30/17 05:59 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
fan
Re: Oil change and now no oil pressure! [Re: DrCharles] #2345808
07/30/17 06:05 PM
07/30/17 06:05 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Another vote to install a different brand filter, pull dist and prime with a drill.
If you don't go that route, pull the filter, pack as much Vaseline into the pump as you can and install a new filter.
Re: Oil change and now no oil pressure! [Re: perfmachst] #2345811
07/30/17 06:10 PM
07/30/17 06:10 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I had an oil pump failure ~ 1975 on my '68 383, don't recall the mileage but well under 100,000 miles. Probably a long shot but don't overlook it either. I stupidly damaged my engine. 2ยข
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Oil change and now no oil pressure! [Re: 500ciBee] #2345812
07/30/17 06:19 PM
07/30/17 06:19 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I've heard too many horror stories on Fram filters, so never used them. Wix, then started to hear they may be producing over seas now too, not sure. Using Baldwin now.
I would definitely pull the filter to start and cut it open. That's cheap and easy, then go from there.
Facts are stubborn things.
Re: Oil change and now no oil pressure! [Re: therocks] #2345846
07/30/17 07:29 PM
07/30/17 07:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I know Fram's are usually junk, but I had this happen recently with a Performance K&N filter on my Trans Am's LS1, oil change/filter, no pressure, changed out filter for another K&N; presto! oil pressure...sounds like quality standards are slipping everywhere!
Re: Oil change and now no oil pressure! [Re: DAYCLONA] #2345896
07/30/17 09:24 PM
07/30/17 09:24 PM
it is.
Re: Oil change and now no oil pressure! [Re: DAYCLONA] #2345928
07/30/17 10:26 PM
07/30/17 10:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
myself,
I say pull the distubutor and drive gear.
Use a drill to run the pump ( don' forget CCW on a BB)]
IF you are building pressure the drill motor will let you know via resistance.
If so, and no pressure registering,
Change the guage,
Still no pressure ?
change the filter and repeat.
I would NOT START THE MOTOR AGAIN until the drill motor produces pressure PERIOD!!
please report back an whether it was a filter problem or not. AGAIN,
twocents beer
Re: Oil change and now no oil pressure! [Re: RapidRobert] #2345929
07/30/17 10:26 PM
07/30/17 10:26 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
another vote for changing the filter. This exact symptom is why i quit using fram filters. On a side note, make sure the o ring off the old filter didn't stay stuck to the pump, either.
Page 1 of 4 1 2 3 4
